need help from pros please
Old May 25, 2009 | 01:57 PM
Popoy's Avatar
Default need help from pros please
hey all, need a little help from audio pros here. see i bought this car, 4th gen lude, and it came with aftermarket tweeters, front speakers (inside door panels), rear speakers and an amp. the previous owner took his subwoofers where the amp was connected to. im just wondering, since he left the amp, could i just hook up the front and rear speakers on it and if i do would the sound be any better? here are the models and some info about them from internet hehe: front speakers: alphasonik Z series PCZ50 (2-way, 100 watts rms, 35Hz - 25kHz), rear speakers: alphasonik Z series PFZ525 (2-Way ,120 Watt RMS, 65 Hz - 22 kHz), Amp: Kicker impulse power amplifier Ix254(Multi Channels, Bridgable, RMS Power at 4 Ohms=25 W x 4, RMS Power at 2 Ohms=35 W x 4) Teeters: just say Z series on a box where wires are hook up to. thanks for helping out
Old May 25, 2009 | 02:08 PM
mrdeadman's Avatar
They let me pick
Default Re: need help from pros please
No. You'd be better off getting rid of the amp. It barely puts out more power than the hu itself...
Old May 25, 2009 | 04:54 PM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
If anything I would bridge it into a 2ch amp and connect only to the front speakers, that will get you 2x65W RMS into 4 ohms @12.5V.
Still only about 50% of what you should have for the fronts, but better then just HU power. 94
Old May 25, 2009 | 10:10 PM
Popoy's Avatar
thanks for the help. do you think i should just buy a cheap subwoofer just to have good bass? cause right now the bass is really weak. thanks
Old May 26, 2009 | 07:28 AM
mrdeadman's Avatar
They let me pick
No. This is also a bad idea. That amp you have is not meant to power a sub at all, it outputs almost no power.
You should:
1. Get a sub you like.
2. Get a new amp that can power/slightly overpower the sub.
3. Obtain a box of correct(ish) dimensions for the sub.
4. Install new system.
JohnnyEF
Audio / Security / Video
May 19, 2010 04:59 AM
rutherfordhigh
Nov 22, 2008 03:38 PM
accord03
Jun 11, 2007 04:23 PM
Problemo
Dec 5, 2003 08:29 AM
schwinn
Jun 19, 2002 10:54 PM
