multiple headunits?
Old Jun 11, 2008 | 08:11 PM
FOUR-G's Avatar
Default multiple headunits?
can i just "splice" another headunit into my factory radio harness?
CDs sound way better when played in my aftermarket player, BUT i don't like the way it looks or the "visual attention" it may attract. so i want to put my factory Honda radio in the factory console location, and hide my aftermarket unit (its got a remote anyways). aaand i want both of them to function.
would doing so affect the sound when using either one?
Old Jun 12, 2008 | 05:07 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">can i just "splice" another headunit into my factory radio harness?</TD></TR></TABLE>
No.
It can be done, but great care needs to be taken to "isolate" each deck's audio from the other, whether you use relays or switches...
Possible? Yes. Worth it, meh, I personally wouldn't bother...
Old Jun 12, 2008 | 08:14 AM
FOUR-G's Avatar
Default Re: (B18C_EJ8)
thanks for the response. i guess i'll just hide the aftermarket one and leave the stock one as a pretty dummy.
Old Jun 12, 2008 | 11:09 AM
mechanix619's Avatar
Default Re: (FOUR-G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOUR-G &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the response. i guess i'll just hide the aftermarket one and leave the stock one as a pretty dummy.</TD></TR></TABLE>
That's really the best way. By the way, the remote is only going to work if it has line of sight with the deck. If you are planning on installing the deck in the glove box the remote wont work.
Old Jun 12, 2008 | 06:07 PM
fcm's Avatar
fcm
Old Fart
Install the aftermarket HU in the stock location, "peel" the front off the stock HU and turn it into a "dummy" plate you can cover the aftermarket HU, [once you remove it's face plate].
If you spend a little time on modding the removed OEM HU face, once it is in place the dash will look stock.
If you want to keep both and have both work you will need two 4PDT and one SPDT relays, an adapter harness, [to fit the stock radio plug] and a rev. harness. [to fit the stock HU] and "great care needs to be taken to "isolate" each deck's audio from the other", all the speaker leads and the stock HUs acc. lead need to be switched, soldered and shrink tubed to the relays.
The "dummy face" is more practical, easier and cheaper. 94
Chavy340
Dec 5, 2013 06:37 PM
TSAngry
Audio / Security / Video
16
Jan 27, 2007 09:02 AM
.Kevin.
19
Mar 29, 2006 08:49 PM
Built B16A
Aug 19, 2004 05:46 PM
AllMotorBrew
Oct 18, 2002 09:30 AM
