mono vs stereo
Old Nov 4, 2004 | 06:45 PM
picott's Avatar
Default mono vs stereo
what is the difference between mono and stereo
...also isnt the lower the ohm the deeper the bass?
Old Nov 4, 2004 | 07:02 PM
bassisliffe's Avatar
Default Re: mono vs stereo (picott)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by picott &raquo;</TD></TR><TR><TD CLASS="quote">...also isnt the lower the ohm the deeper the bass?</TD></TR></TABLE>
not technically uhh forget it someone smart will explain
Old Nov 4, 2004 | 07:11 PM
picott's Avatar
Default Re: mono vs stereo (bassisliffe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">
not technically uhh forget it someone smart will explain </TD></TR></TABLE>
i hope so, i dont wanna buy the wrong shiot
Old Nov 4, 2004 | 07:51 PM
hometheaterman's Avatar
STereo is two channels Mono is one. So if you have a cd with stereo saying you have two speakers hooked up to stereo equipment and one speaker on each side you would hear differnt sound effects out of each side versus with mono it would be the exact same thing. For OHM's I'm not the best to explain it as I'm not the best explaining stereo even though I know exactly what it is if you need further help I can probably answer questions about stereo vs. mono if you have any. For OHM's like if you have an amp that runs 400W at 4ohms you could run more if you ran it at 2ohms probably like 600W with 2ohms. Depends on what subs and amp your want or if your running speakers what speakers or amp or HU you want you cant run a 4 ohm sub with an amp at 2ohm's. Well you mabe could but it would not be a good idea nor would it be stable.
Old Nov 4, 2004 | 08:00 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by picott &raquo;</TD></TR><TR><TD CLASS="quote">what is the difference between mono and stereo
...also isnt the lower the ohm the deeper the bass?</TD></TR></TABLE> Mono = one channel, stereo = two channels left and right, but it has more to do with the recording, you can record in mono on a stereo recorder, it is what and at what gain you record on to the left and right channels that gives you the stereo image that you hear on your stereo, then there is surround sound 5.1 or 6.1 but thats another story.
As for lower OHMs make deeper bass. NO 94
Old Nov 4, 2004 | 09:05 PM
Mr. Thunderlips's Avatar
Ohm: The unit of measurement of electrical resistance. The resistance of a circuit in which a potential difference of 1 volt produces a current of 1 ampere.
The lower the ohm load, the more effecient the amplifier is, hence more power into your speaker.
Old Nov 4, 2004 | 10:04 PM
CarAudioPro's Avatar
Default Re: mono vs stereo (Mr. ThunderLips)
mono one channel(L+R), stereo is left and right. if your running speakers you'd want to run stereo for left and right. if your running subs, itas not about deeper bass, its about how your subs are wired, and what ohm loads you have to get the most out of your amp.
Old Nov 5, 2004 | 07:52 AM
picott's Avatar
Default Re: mono vs stereo (hometheaterman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman &raquo;</TD></TR><TR><TD CLASS="quote">STereo is two channels Mono is one. So if you have a cd with stereo saying you have two speakers hooked up to stereo equipment and one speaker on each side you would hear differnt sound effects out of each side versus with mono it would be the exact same thing. For OHM's I'm not the best to explain it as I'm not the best explaining stereo even though I know exactly what it is if you need further help I can probably answer questions about stereo vs. mono if you have any. For OHM's like if you have an amp that runs 400W at 4ohms you could run more if you ran it at 2ohms probably like 600W with 2ohms. Depends on what subs and amp your want or if your running speakers what speakers or amp or HU you want you cant run a 4 ohm sub with an amp at 2ohm's. Well you mabe could but it would not be a good idea nor would it be stable. </TD></TR></TABLE>
im planning on buying a pair of audiobahn 1206t's, as for an amp im looking at memphis's line because ive heard of many people regard their level of prestiege, door speakers and headunit arent a priority to many honestly(imo they are all the same)
Old Nov 5, 2004 | 08:08 AM
rcurley55's Avatar
New User
http://www.bcae1.com
get to reading, it has all the answers you are looking for and more
Old Nov 5, 2004 | 10:22 AM
EBP_SI's Avatar
im planning on buying a pair of audiobahn 1206t's, as for an amp im looking at memphis's line because ive heard of many people regard their level of prestiege, door speakers and headunit arent a priority to many honestly(imo they are all the same)</TD></TR></TABLE>
so all door speakers are the same? ineteresting
btw...audiobahn is a joke
Modified by EBP_SI at 8:08 PM 11/5/2004
Old Nov 5, 2004 | 11:15 AM
Default Re: mono vs stereo (EBP_SI)
I ususally stick up for Audiobahn but I don't think I would buy one of there subs. I might as a last resort but I really don't even think I would then. They sound muddy and sound like crap to me. I like there Amps and think they are good budget amps despite what many people say but there subs sound like ****. The amps don't put out nearly the power they claim but I like them a lot for budget amps but I just don't like the SUB's at all. I would look at Polk MOMO or many other brands I just like the Polk MOMO subs the best but I'm sure there are ones a lot better out there somewhere.
Old Nov 5, 2004 | 11:18 AM
I noticed a huge differnce in sound quality when I upgraded my HU and noticed another fairly big increase in sound quality with my speaker upgrad although not quite as good. I think you need a good set of speakers before a sub. I prefer a good set of speakers to subs but I have about decided that is because everyone I know that is really into music don't really like subs all that much but set up there systems and spend more time tweaking them than installing them which I also do so they sound better than the systems with subs that arnt set up properly because I haven't seen many setups with subs that are setup correctly althoouh I have seen 1 or 2.
Old Nov 5, 2004 | 02:29 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman &raquo;</TD></TR><TR><TD CLASS="quote">I noticed a huge differnce in sound quality when I upgraded my HU and noticed another fairly big increase in sound quality with my speaker upgrad although not quite as good. I think you need a good set of speakers before a sub. I prefer a good set of speakers to subs but I have about decided that is because everyone I know that is really into music don't really like subs all that much but set up there systems and spend more time tweaking them than installing them which I also do so they sound better than the systems with subs that arnt set up properly because I haven't seen many setups with subs that are setup correctly althoouh I have seen 1 or 2. </TD></TR></TABLE>
in my eyes the proper order to do things is
Take rear speakers out of the car
Get an HU
front speakers
amp for the front speakers
then a sub and amp combo.
as far as having a setup without a sub...i've yet to see one that will produce anythign below 50hz so that call is up to you. the only thing to do is keep it in proportion with the mids.
ATS*VEEE
Jul 9, 2007 03:22 PM
2point2
Jun 13, 2005 10:48 AM
