Mid speaker in the way of the window?
Old Apr 27, 2004 | 04:32 PM
CivHatchH22's Avatar
Default Mid speaker in the way of the window?
I just bought Alpine Type R components for my 00 Civic HB and i've heard of aftermarket mid's being in the way of the window... happen to any of you and what did you do?
Old Apr 27, 2004 | 08:25 PM
Default Re: Mid speaker in the way of the window? (CivHatchH22)
Old Apr 27, 2004 | 08:28 PM
vteg's Avatar
New User
Make an mdf spacer.
Old Apr 28, 2004 | 06:34 AM
pnthr30's Avatar
Default Re: Mid speaker in the way of the window? (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">Make an mdf spacer.</TD></TR></TABLE>
exactly........it isn't hard at all, and will give you a lot more room (relatively speaking).
Old Apr 28, 2004 | 08:04 AM
what about the speaker cover?
Old Apr 28, 2004 | 01:44 PM
pnthr30's Avatar
I made a mdf spacer (3/4") for some Infinity components in my 99 Integra GS sedan and there was still room to put the door panel back in and use the stock speaker cover. I had to do a little creative cutting and shaving because I made the spacer a bit to big, but it fits great now. How much extra depth do you need? I would say give it a try and see how it works (I am guessing you should be fine in regards to depth once you use a 3/4" spacer - and chances are that the door panel and stock speaker grill will fit (but I cannot say for sure because I have never worked on a civic)). If you are interested, there is a pretty good DIY about this over at team-integra.net (in the articles section).
Hope this helps! Good luck.
Old Apr 29, 2004 | 11:32 PM
Default Re: Mid speaker in the way of the window? (pnthr30)
ne pics?
Old Apr 30, 2004 | 04:47 AM
georgelb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivHatchH22 &raquo;</TD></TR><TR><TD CLASS="quote">ne pics?</TD></TR></TABLE>
something kinda like this
Old Apr 30, 2004 | 09:05 AM
Default Re: Mid speaker in the way of the window? (georgelb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgelb &raquo;</TD></TR><TR><TD CLASS="quote">
what about the cover?
Old Apr 30, 2004 | 09:15 AM
TnTWRX's Avatar
I was having problems with my Focals in the door but with a 3\4" spacer everything fit fine. I did have to trim one of the speaker covers but it still fits in there nice and secure
Here are a couple of crappy pics of the fitament in a 96 GSR
Old Apr 30, 2004 | 10:33 AM
georgelb's Avatar
what about the cover?</TD></TR></TABLE>
You test fit and trim until it is right.
I had lots of time to test fit
Makeshift a-periodic doorpods own.
Old Apr 30, 2004 | 07:49 PM
vteg's Avatar
New User
I like that!
Old May 1, 2004 | 08:00 AM
TnTWRX's Avatar
Very nice
Old May 1, 2004 | 08:04 PM
jdmotorsports's Avatar
Default Re: Mid speaker in the way of the window? (TnTGSR)
i used metra 1/2" spacer with my nakamichi comps. works great.
Old May 2, 2004 | 05:27 AM
jordan-boxer's Avatar
Default Re: Mid speaker in the way of the window? (jdmotorsports)
GREAT TOPIC AND PICS!
Old May 2, 2004 | 06:39 PM
wHOAlly's Avatar
can u explain why u made them enclosed? aint it kinda small? very nice work
Old May 2, 2004 | 08:52 PM
Default Re: Mid speaker in the way of the window? (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n'd Supra &raquo;</TD></TR><TR><TD CLASS="quote">
can u explain why u made them enclosed? aint it kinda small? very nice work </TD></TR></TABLE>
same reason you put a sub in a sealed box, better lowend response.
Old May 2, 2004 | 11:32 PM
georgelb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">
same reason you put a sub in a sealed box, better lowend response. </TD></TR></TABLE>
Yep, but I had MAD power handling in mind too. However, with it completely sealed it was indeed too small, I made the box miniscule and there is basically just enough room for the mid and a good dose of polyfill in there. There was TONS of midbass, but it was peaky, so that is when I decided to modify them and go a-periodic. I cut a hole in the back, and covered it with gortex material to weatherproof it (entire back is coated in fiberglass resin for same reason) and then put in the mat. This seriously flatened out the response curve because it can breath to the outside...and since it is still acting like it is in a sealed enclosure, the power handling is awesome too. I still need to get some grille metal and insulation and do the mat right, I will probably do that when I pull them out and finish the baffle.
Old May 3, 2004 | 12:18 AM
wHOAlly's Avatar
Yep, but I had MAD power handling in mind too. However, with it completely sealed it was indeed too small, I made the box miniscule and there is basically just enough room for the mid and a good dose of polyfill in there. There was TONS of midbass, but it was peaky, so that is when I decided to modify them and go a-periodic. I cut a hole in the back, and covered it with gortex material to weatherproof it (entire back is coated in fiberglass resin for same reason) and then put in the mat. This seriously flatened out the response curve because it can breath to the outside...and since it is still acting like it is in a sealed enclosure, the power handling is awesome too. I still need to get some grille metal and insulation and do the mat right, I will probably do that when I pull them out and finish the baffle.</TD></TR></TABLE>
cool ****, i always wondered why not many made a mini box/enclosure for the midranges...but dam, didnt realize it could be so small and be effective
Frstyl838
Audio / Security / Video
Jul 28, 2008 01:37 PM
BORACHO
37
Dec 2, 2007 03:02 PM
. O M E G A
Nov 19, 2005 06:36 PM
93HatchCali
Mar 2, 2005 03:26 PM
GroundZer0
17
Jul 9, 2003 10:26 PM
