master disconnect switch
Old Jul 5, 2008 | 08:41 PM
Kid_SiR's Avatar
Default master disconnect switch
hi i recently relocated my battery too the back of my car an in order for me too run at the track i need too install a master disconnect switch but i never done it before can anyone help me out ????
Old Jul 6, 2008 | 05:33 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: master disconnect switch (Kid_SiR)
were is the battery located at?
Old Jul 6, 2008 | 07:47 AM
Kid_SiR's Avatar
its in the trunk but they told me at the track it needs too turn the car offf when its on in order too past safty
Old Jul 6, 2008 | 10:19 AM
fcm's Avatar
fcm
Old Fart
Default Re: (Kid_SiR)
You need one of these... http://www.pegasusautoracing.c...=1465, connect batt. pos.(+) cable to one side and run the same gauge lead from the other terminal to the batt. pos.(+) terminal. 94
Old Jul 6, 2008 | 04:42 PM
Kid_SiR's Avatar
well i already have that but the way u explain it it wont shut the car offf it will just cut the power off
Old Jul 7, 2008 | 06:03 PM
fcm's Avatar
fcm
Old Fart
Like a "dead mans" switch?
Like you see on Sea-Doos and quads and such, a landyard, [string] around your wrist with a plug at the end plugged into the dash and if pulled out shuts the engine down.????
What exactly is the rule, can it just be a switch that you can flip or a button you can push, or must it be like a "dead mans" switch? 94
Old Jul 7, 2008 | 09:50 PM
Default Re: (fcm)
This is what i use on my car for drag
http://store.summitracing.com/...w=sku
It kills the battery and the ignition at the same time. This is what you need.
Robert Slinkard
Mar 10, 2018 08:26 AM
Type-Spaz
Aug 19, 2011 07:19 AM
RedneckRicer
Oct 20, 2008 06:47 PM
domsb16
Dec 9, 2007 04:23 PM
servion
Feb 12, 2005 04:47 AM
