L7 compared to L5?
Old Jan 7, 2007 | 09:43 AM
nate_2k5's Avatar
Default L7 compared to L5?
how do the kicker solo L7 and L5 compare?
has anyone heard a S8L7? good? bad?
Old Jan 7, 2007 | 11:18 AM
fcm's Avatar
fcm
Old Fart
Default Re: L7 compared to L5? (nate_2k5)
Other then the L7 8" being a 450W/900W sub and the L5 8" being a 300W/600W sub they are pretty much the same, using the same sized cabinets, and for an 8", [either one] they sure belt out the bass. 94
Old Jan 7, 2007 | 11:53 AM
nsxxtreme's Avatar
Default Re: L7 compared to L5? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Other then the L7 8" being a 450W/900W sub and the L5 8" being a 300W/600W sub they are pretty much the same, using the same sized cabinets, and for an 8", [either one] they sure belt out the bass. 94</TD></TR></TABLE>
How small of a box?
I need something that uses a really small box. Thinking of uses one of those new pioners.
Old Jan 7, 2007 | 12:24 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: L7 compared to L5? (nsxxtreme)
^^^^^^ which ones?
Old Jan 7, 2007 | 12:38 PM
nsxxtreme's Avatar
Default Re: L7 compared to L5? (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^ which ones?</TD></TR></TABLE>
These ones.
I was thinking one of these in a 10 or an 8inch kicker L5.
The NSX sub is in the passenger floorboard. I bought an illusion audio 10 a while back and it sucked IMO.
Old Jan 7, 2007 | 12:47 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">
How small of a box?
I need something that uses a really small box. Thinking of uses one of those new pioners.</TD></TR></TABLE> .33 sealed, [compact min.] and .75, [SQ max.] and .66+ port displacement, [vented min.] and 1.0+ port displacement, [vented max.]
http://www.kicker.com/06/tech-...B.pdf The L7 is pretty much the same.
If room is an issue, maybe look into the JL Audio 6W0... http://mobile.jlaudio.com/prod...id=23 94
Old Jan 7, 2007 | 12:49 PM
nsxxtreme's Avatar
No room for a port would have to be sealed.
Was hopping for a little bit bigger speaker then a 6
Old Jan 7, 2007 | 04:06 PM
nsxxtreme's Avatar
How about a suggestion of a really good 6X9?
I have a 94 Accord EX as my beater.
Would like to put a decent set of 6X9's that are capable of some bass. Then I can get rid of the 12's in the trunk and get my trunk space back.
Old Jan 7, 2007 | 04:44 PM
nate_2k5's Avatar
Default Re: (nsxxtreme)
any decent 6x9's will work, run a decent amount of juice to them (around their rms rating), they'll sound even better if you put them in small boxes. mtx or kicker will work good
also how is the output comparison between the l5 anf l7?
Old Jan 7, 2007 | 08:25 PM
shibbywhitedude's Avatar
I know you moved from the subject of a Solobaric 8 but my buddy has 2 L7 8s in his Firebird and I'd put them up against alot of 10s and even some 12s... Just get a good amp for them lol
Old Jan 7, 2007 | 10:56 PM
nate_2k5's Avatar
Default Re: (shibbywhitedude)
i got an audiobahn mono amp thats gonna run 400w RMS at 4 ohm to one of them
edit: i had this same amp running 400w RMS to each at 2 ohm to 2 audiobahn 12's and it performed admirably
Old Jan 8, 2007 | 09:09 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">How about a suggestion of a really good 6X9?
Would like to put a decent set of 6X9's that are capable of some bass. Then I can get rid of the 12's in the trunk and get my trunk space back.</TD></TR></TABLE> Find an Eclipse dealer and have a listen to their... http://www.eclipse-web.com/point/sp6900.html even the ... http://www.eclipse-web.com/integrated/se8495.html remove or disconnect the tweeters, but my guess is you will be impressed with their bass response, very tight and clean, put a 2x100W RMS amp on the point source and be very impressed. 94
Old Jan 8, 2007 | 09:23 AM
fcm's Avatar
fcm
Old Fart
Oh, you said "really good", then you may want to look at the HERTZ High Energy HCX 690, a really good 6x9 or maybe the Energy ECX 690 or Dieci DCX 690... http://www.hertzaudiovideo.com/default_en.htm 94
Like Butter
Audio / Security / Video
61
Apr 9, 2006 01:31 PM
96civicHATCH
11
Nov 8, 2005 08:28 AM
92orangeeg
Jan 31, 2005 07:49 AM
mr poo
Jan 30, 2005 07:37 AM
feelthebreak
Oct 10, 2004 09:40 PM
