Killswitch amp rating?
Looking to bump up the security in my hatch, so I'm planning on a battery kill switch and a fuel pump kill switch. Searched and found various DIYs, but I was wondering what amp rating i should use for switches.
The battery kill switch i was looking at has 100 continuous amp rating, 500 surge amp rating, will that suffice? its an OEM 500CCA honda battery relocated to the trunk
The fuel pump kill switch i was planning on just an autozone on/off switch, but would the switch heat up without a relay? what amp rating should i use?
thanks in advance for any input
http://www.team-integra.net/forum/17...switch-g3.html
won't go into too much detail about my kill switch on here, but this is the guide I used...found it really helpful
He says in it about not going below 20 amp, but pretty sure when I done mine I used 16 or 17amp and have no problems what so ever.
http://civic-eg.com/causeforalarm/fu...killswitch.gif
Keep in mind the fuel pump kill is easily bypassed by running a power wire from the battery to the fuel pump.
Also, the link is for a main relay kill switch, not a fuel pump kill switch; totally different. And he's using a 5amp switch, no mention of 20amp. The main relay kill is for a ground and it's only putting out a few milliamps.
The main relay is disrupting the ground wire whereas the fuel pump is disrupting the power wire.
aleks77
Audio / Security / Video
Apr 8, 2007 11:27 AM
OrangeBoost
Mar 29, 2005 10:37 PM
