Kicker l5 sub
Old Mar 30, 2009 | 06:52 PM
deerman2701's Avatar
Default Kicker l5 sub
Ok so i have one 2 ohm dvc kicker sub that is 600 rms what amp would you get a non cea compliant 600 rms mono amp or a non cea compliant 760 rms amp 2 channel
Old Mar 30, 2009 | 07:04 PM
Default Re: Kicker l5 sub
http://www.bestbuy.com/site/olspage....=1218012144318 or http://www.bestbuy.com/site/olspage....=1218012127692
Old Mar 31, 2009 | 06:16 AM
fcm's Avatar
fcm
Old Fart
Either one will work, the 2ch has the advantage of more RMS power but the mono block makes a better sub amp. 94
Old Mar 31, 2009 | 01:31 PM
Ok so do you think i should get the 2 channel amp since the rms advantage because its not cea compliant or will i be safe
Old Mar 31, 2009 | 01:32 PM
How many watts would they be pushing in reality or is there another brand that i can buy thats cheap like this and is cea compliant
Old Mar 31, 2009 | 04:06 PM
fcm's Avatar
fcm
Old Fart
Like I said, either one will work, if your looking for something else, look for a mono block amp with 600W-750W RMS.
No matter what amp you get, as long as you do not drive the amp into constant clipping and the sub is in a proper enclosure, you will not hurt the sub.94
Old Mar 31, 2009 | 06:08 PM
Yea thanks i just didnt know if i should get the 600 watt one since the rms for the sub is 600 or to get 760 but i thought the 760 would be too powerful or no?
Old Apr 1, 2009 | 05:29 AM
fcm's Avatar
fcm
Old Fart
It's better to be overpowered then it is to be underpowered.
Keep in mind that your sub is 600W continuous and 1200W peak, also remember music is dynamic, even when volume is cranked up it is very seldom amp will make it's RMS wattage, just on the loudest peaks of the music and then only for a sec. the rest of the time the amps output will be less then rated RMS output and the average RMS output will be less then 50% of rated RMS output.
Also keep in mind the amp has a gain control so you can adjust the amps output to match what your sub will handle, that will also depend on the cabinet the sub is in, and how well it is constructed, in fact I would be far more concerned with the sub box then the amp running the sub. 94
Old Apr 1, 2009 | 05:55 AM
I built the box so its ok built to kicker specs
Old Apr 4, 2009 | 09:38 PM
mattison187's Avatar
why run it at 4ohms? get an amp rated for 600 or so rms @ 1ohm. whatever you deside id go with class D not an a/b multi channel
Old Apr 5, 2009 | 08:45 AM
fcm's Avatar
fcm
Old Fart
Because at 4 ohms you will get much better SQ then a 1 ohm.
I do agree that a mono block sub amp would be better then a 2ch amp. 94
Old Apr 5, 2009 | 12:35 PM
the ohms load has nothing to do with soundquality as long as your getting a clean signal...
Old Apr 5, 2009 | 04:51 PM
fcm's Avatar
fcm
Old Fart
LOL, look up "dampening factor" 94
Old Apr 5, 2009 | 04:55 PM
lol dampening factor has nothing to do with SQ. id like you to listen to the same sub/same enclosure with an amp @ 1 then @ 4. same rms. bet you couldnt say wich is wich
Old Apr 6, 2009 | 07:11 PM
http://www.sonicelectronix.com/item_...KAC-9104D.html or that amp since its cea 2006 compliant but its 100 rms less than i need
Old Apr 7, 2009 | 05:39 AM
fcm's Avatar
fcm
Old Fart
Bet you a dollar I can.
http://www.prosoundweb.com/article/damping_factor/ 94
Old Apr 7, 2009 | 05:46 AM
fcm's Avatar
fcm
Old Fart
I would still go with the first mono block... http://www.bestbuy.com/site/olspage....=1218012127692, just for the extra 100W. 94
ChiLS
Audio / Security / Video
Feb 21, 2009 10:16 AM
kingbrian
Oct 1, 2008 09:20 AM
diewnaylomoah
Jul 27, 2007 05:48 AM
Corporation
May 7, 2006 11:19 AM
VietFoo
Dec 25, 2005 12:03 AM
