Kicker amp and sub compatibility
Old Aug 22, 2006 | 05:02 PM
cockerkid008's Avatar
Default Kicker amp and sub compatibility
Ive been loking at a new set-up for my car im already getting a new wiring kit.
Im just wonder if these would work good together
06 kicker 12'' L7
* 12" subwoofer with dual 4-ohm or dual 2-ohm voice coils
* Power range: 50-750 RMS watts
* Peak power: 1500 watts
* Frequency range: 20-100 Hz
* Sensitivity: 87.4 dB
* Sealed box volume: 0.88-2.00 cubic feet
* Ported box volume: 1.75-3.25 cu. ft.
The box that I wuld build would be a 2.5 cf ported box.
06 Kicker ZX1000.1 amp
* RMS Power: 500W x 1 @ 4 ohms
* RMS Power: 1,000W x 1 @ 2 ohms
* THD at 4-Ohm RMS Power: <1 %
* Bass Boost: 0 - 18 dB
* Frequency Response: 25-200Hz
* Signal to Noise Ratio: 60 dB
* Efficient class D circuitry
* KickBass 0-18 dB variable bass boost at 40 Hz
* Variable 50-200 Hz low-pass crossover with 24 dB/octave slope
* Defeatable 25 Hz subsonic filter
* High level or low level inputs (125mV-10V)
* PreAmp Signal Transfer (PAST) RCA outputs
* Included remote KickBass control
1. I was just wonder if the amp would be a little overkill for the sub or just right.
2. Should i get the 2 or 4 ohm sub. I was thinking of getting the 4ohm dvc and wire it to a 2 ohm load.
Thanks for the help!
Modified by cockerkid008 at 10:25 PM 8/22/2006
Old Aug 22, 2006 | 05:22 PM
mrdeadman's Avatar
They let me pick
Default Re: Kicker amp and sub compatibility (cockerkid008)
I would get the dual 4 ohm voice coils and wire it to 2 ohms. The amp will probably be fine as long as you don't abuse it. Or you could get the dual 2 ohm voice coils and wire it to 4 ohms as well if you were worried about overkill.
Old Aug 22, 2006 | 05:25 PM
Default Re: Kicker amp and sub compatibility (mrdeadman)
im sorry for the confusion you can get it in either 4 or 2 ohm dvc
Old Aug 22, 2006 | 05:26 PM
mrdeadman's Avatar
They let me pick
I just figured that out... haha. Reading owns me.. so i edited my first post.
Old Aug 22, 2006 | 05:38 PM
thnaks for the quick help!!
Thats what ive been thinking about getting the 4ohm dvc like you said.
Anybody have any issues with these items??
builthatch
Audio / Security / Video
11
Jan 30, 2011 08:34 AM
marcus27
Jan 30, 2005 11:43 AM
ncVTEC1313
Apr 27, 2004 05:44 PM
Hasboro
Dec 20, 2003 10:49 AM
SilverDc2
Apr 30, 2003 09:29 PM
