anybody have experience with this driver?
http://mobile.jlaudio.com/products_s...p?series_id=30
this speaker seems ideal for my goals- high impact shallow sub that requires minimal volume...and is a "sealed only" sub. i need to figure out a solution for my tacoma double cab.
the biggest issue seems how to power it - 3 ohms, doh!
Just get an amp that is 1ohm stable and your fine. 2 of those in parallel will give you a 1.5ohm load.
I used one in tundra crewmax with plenty of power and it was horrible. I tried 3 different boxes, sealed as recommended, larger sealed, and ported. None of them sounded good. Low output and craps out with more power. I was definitely disappointed especially considering the price. I would use a couple 6" before another one of these.
the last truck we a built a shallow box for we used 4 8" jl subs in a single chamber...the 8w1v2 has a mounting depth of less then 4 inches.
They're very niceeeeeeeeeeeeeeeee...not so much for what jl asks..but they perform well.
check these out too
http://www.polkaudio.com/caraudio/mm...ew-subs#mm1040
and
http://stereointegrity.com/index.php?id=47
^^best shallow mount i've ever heard
These too
http://www.parts-express.com/pe/show...number=295-134
check these out too
and
These too
Quote:
check these out too
and
These too
i like the features of that stereo integrity piece but they aren't available.Originally Posted by edzy
They're very niceeeeeeeeeeeeeeeee...not so much for what jl asks..but they perform well.check these out too
and
These too
well, i finally got around to emailing the contact on the SI site so we'll see what happens.
I think they're still out of stock. They're is a thread DIYMA about the new Alpine Type-R's, and there was an Alpine engineer on there discussing them and I must say I was pretty impressed. It appears they actually spent some time on quality re-engineering them and did some important things like focusing on linearizing BL, etc. There was more info in there about the normal R's than the Slim's from what I recall, but they put the same focus into the Slim line so I wouldn't be surprised if they were solid drivers as well.
Quote:
thanks.Originally Posted by mrmondaynight
i ran a type r 12 in my ms3 in a winisd spec'd box and it was amazing. i considered the slims but i figured this would be a nice opportunity to try a boutique sub since i've always stuck with alpine. plus the price, ugh! i will have first get type r components up front and a pdx 4.150 running them and the sub - all of that equipment is the same setup i had in my ms3 and it was ample.
Old Fart
I have installed two of them in an older Chev PU, using the 500/1 amp to drive them, it worked out OK, customer was happy, however I have to agree with, 2k.civic.si, I did the 8W1v2, 4 of them in single sealed box, two per chamber, also with the 500/1, it was much better then the two 13TW5s. 94
i've never seen a JL sub worth the money they want for them, that being said, go with some kind of 8" sub, the DC Audio LVL2 8" is a great sub, depending on how much mounting depth you have.
