is the kicker 07cvr a good sub?
Old Oct 2, 2007 | 03:09 PM
racerose's Avatar
Default is the kicker 07cvr a good sub?
i was looking into putting 1 12" 07cvr sub into my civic and just needed some feedback on the sub
Old Oct 2, 2007 | 03:39 PM
B18C_EJ8's Avatar
What are you going to power it with?
Old Oct 2, 2007 | 03:53 PM
johnson_n's Avatar
Default Re: (B18C_EJ8)
Theyre ok. CVX's get louder.
Old Oct 3, 2007 | 08:40 AM
racerose's Avatar
i know the cvx's get louder they're double the power and what type of box should i get ported or sealed for this sub
Old Oct 3, 2007 | 09:04 AM
racerose's Avatar
i found a transmission line slot ported box that is 2.22 cubic feet for $69.00 through caraudiofactory.com never heard of them but the price is good let me know what you guys think
Old Oct 3, 2007 | 10:15 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">What are you going to power it with?</TD></TR></TABLE>
Old Oct 3, 2007 | 10:54 AM
eskimo10's Avatar
^agreed. A sub generally is only as good as the amp that pushes it.
Old Oct 3, 2007 | 02:29 PM
racerose's Avatar
i bought a hifonics zues zxi4006 it throws 400rmsx1 at 4ohms
Old Oct 3, 2007 | 04:31 PM
racerose's Avatar
i gave you guys the amp now should i buy a sealed or ported box
Old Oct 4, 2007 | 02:24 PM
racerose's Avatar
thanks for the help not you guys ask me what i'm powering the sub with and now don't answer my question
Old Oct 4, 2007 | 03:47 PM
B18C_EJ8's Avatar
It's a good sub.
Old Oct 4, 2007 | 04:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: (racerose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerose &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help not you guys ask me what i'm powering the sub with and now don't answer my question</TD></TR></TABLE>Calm down, this form does not move that fast.
Yes the sub is OK, it will work pretty well with that amp in a small sealed box, [1 cuft net], a "SQ" box will need to be about 4.5 cuft, [sealed] although the power handling drops to 300W continuous in the bigger box.
It will also work in a vented box, [slot port] 1.75 -2.25 cuft + port displacement, again power handling is 300W continuous, in vented boxes.
The owners manual you get with the sub will have all the info you need for box size and construction and VC wiring.
The above assumes you are talking about the COMP VR 12"... http://www.kicker.com/06/tech-...b.pdf
and not the COMP VR D-Series 12"... http://www.kicker.com/06/tech-...n.pdf 94
Old Oct 4, 2007 | 04:24 PM
racerose's Avatar
so basicly buy a 1.0 cubic feet sealed box
Old Oct 5, 2007 | 04:04 PM
racerose's Avatar
anyone fcm is that what you meant?
Old Oct 5, 2007 | 04:27 PM
fcm's Avatar
fcm
Old Fart
Yes, I think that was one of the options. 94
Old Oct 5, 2007 | 06:50 PM
Mr. Opportunist's Avatar
Not true that CVX's are louder, CVR's can get loud in the proper ported enclosure. They are great subs I recommend them.
Old Oct 5, 2007 | 07:02 PM
johnson_n's Avatar
Default Re: (Mr. Opportunist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Opportunist &raquo;</TD></TR><TR><TD CLASS="quote">Not true that CVX's are louder, CVR's can get loud in the proper ported enclosure. They are great subs I recommend them.</TD></TR></TABLE>
If you build the CVX's in the proper enclosure they get louder than the CVR's...
Old Oct 6, 2007 | 01:59 PM
racerose's Avatar
i'm just gonna get a ported box 1.75 cubic feet
Old Oct 6, 2007 | 02:25 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnson816 &raquo;</TD></TR><TR><TD CLASS="quote">
If you build the CVX's in the proper enclosure they get louder than the CVR's...</TD></TR></TABLE>
Let's see, you have a 750W sub and a 400W sub, you put both in proper boxes, power them properly, and the 750W sub is louder, well hell who knew, maybe Hatch will make it a sticky. 94
Old Oct 6, 2007 | 02:33 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerose &raquo;</TD></TR><TR><TD CLASS="quote">i'm just gonna get a ported box 1.75 cubic feet</TD></TR></TABLE> It's not that easy, when using vented boxes it is critical that box volume and port volume are correct for the sub, unlike a sealed box where 10% +/- volume will make no differance, that you can hear, 10% off on volume of the vent can make a day and night differance.
For optimum output and SQ the box needs to be built to spec, that is even more important with vented boxes, and downright critical with band-pass boxes. 94
Old Oct 6, 2007 | 02:45 PM
racerose's Avatar
i was just gonna buy one from the store not build it
mrdeadman
Audio / Security / Video
13
Mar 15, 2007 10:20 AM
pbizzlegsr
Nov 2, 2006 01:18 PM
DavidT or VajT
Northern California (Sales)
31
Apr 22, 2006 08:54 PM
Like Butter
61
Apr 9, 2006 01:31 PM
D-ray
May 12, 2004 07:08 PM
