Keyless entry - stuck in programming mode
Old Jan 9, 2009 | 05:26 AM
mizerb16's Avatar
Default Keyless entry - stuck in programming mode
Hey, i got a `99 civic keyless factory system installed.
I purchased the remote year ago, programmed according to instructions and it worked ok.
However - recently i changed the battery in it so it stopped working - i figured - i need to programm it again but this time - the freakin unit won`t go out from the programming mode.
I do all the key routine, then get the key off and everytime i manually press the switch to lock/unlock the car the power lock still do this "cycling" sound - what means that it`s still in programming mode.
The keyless remote is working like once on 5-8 pushes - i guess that is because the damn module is learning the remote everytime i push it.
I tried to disconnect the battery to reset teh module - no luck.
How can i FORCE the module to exit that state ? any ideas ? Disconnecting the power out of it is not making any difference.
Should i look into module or maybe i should look into the receiver itself ?
Old Jan 10, 2009 | 09:30 AM
mizerb16's Avatar
Default Re: Keyless entry - stuck in programming mode
bumpzzzz
Old Jan 11, 2009 | 01:58 PM
mizerb16's Avatar
:d
Old Jan 13, 2009 | 09:40 AM
dubrider's Avatar
try flipping the switch to valet mode if its a DEI product. most of them have it. or go to the manufactures website and see if they are diffrent ways to re porgram
chriskinlaw
Dec 29, 2018 04:25 PM
type-r 01 886
Aug 28, 2005 08:17 PM
91DroppedHatch
Audio / Security / Video
Jun 17, 2005 01:31 PM
threatcon13
Jun 9, 2003 07:03 PM
sshaikh01
16
Jun 26, 2002 12:07 AM
