KEYLESS ENTRY STOPPED WORKING --> NEED HELP!!
Old Jun 29, 2005 | 08:52 PM
nyjets05's Avatar
Default KEYLESS ENTRY STOPPED WORKING --> NEED HELP!!
I am in the process of installing aftermarket head unit...I took apart my dash and pulled out the stock radio by taking out the three things plugged in the back. I moved the stock radio below just like http://www.installdr.com shows, and replugged the pieces to try to get my keyless back temporarily. I have not even put the aftermarket unit in yet, and my keyless entry is already not working. All i did was pull 3 wires out and put them back in...can anyone tell me what is wrong...I would appreciate ANY help so much!
Old Jun 30, 2005 | 12:50 PM
fcm's Avatar
fcm
Old Fart
Default Re: KEYLESS ENTRY STOPPED WORKING --> NEED HELP!! (nyjets05)
If all the fuses are good, the stock HU still works, and the keyless entry fuse is ok, you may have to reprogram the remote. 94
Old Jun 30, 2005 | 01:18 PM
nyjets05's Avatar
so i just check the fuse box for blown fuses and replace if any are blown? if none are blown, how would i go about reprograming the remote?
(I am really confused its not like i ripped wires out, i just simply pulled the plug moved the unit below and replugged it with my T harness from tweeter)
Old Jun 30, 2005 | 05:52 PM
fcm's Avatar
fcm
Old Fart
You will have to check your owners manual for programing, or go to your local Honda dealer and have them print it out for you, BTW do the power door lock switch's on the door still work? 94
Old Jun 30, 2005 | 10:24 PM
nyjets05's Avatar
EVERYTHING IS FIXED....NEVER MIND
BUT I DO HAVE ONE MORE PROBLEM... I PULLED THE STOCK RADIO OUT BY REMOVING TWO SCREWS THAT HELD IT INTO A STEEL BEAM....MY AFTERMARKET UNIT DOES NOT REACH THIS BEAM...HOW DO I SCREW IN MY AFTERMARKET JVC UNIT????
Old Jul 1, 2005 | 05:24 AM
Loccusst's Avatar
You don't...you need to go get a dash kit. The aftermarket will not have areas for you to bolt into under it, only on the sides. You need the kit so you can slide a metal cage in.....this is what the stereo attaches to.
Old Jul 1, 2005 | 07:28 AM
99IntegraGS's Avatar
Default Re: (Loccusst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loccusst &raquo;</TD></TR><TR><TD CLASS="quote">You don't...you need to go get a dash kit. The aftermarket will not have areas for you to bolt into under it, only on the sides. You need the kit so you can slide a metal cage in.....this is what the stereo attaches to.</TD></TR></TABLE>
In my daughter's '98 Accord Coupe I was able to remove the brackets from the stock stereo and bolt them to the Alpine unit I was installing. I didn't use the cage and it made for a much nicer install when paired with a storage pocket. I wish I could install my Alpine unit the same way in my Integra. It is a much stronger mounting system.
Old Jul 1, 2005 | 10:30 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyjets05 &raquo;</TD></TR><TR><TD CLASS="quote">EVERYTHING IS FIXED....NEVER MIND
BUT I DO HAVE ONE MORE PROBLEM... I PULLED THE STOCK RADIO OUT BY REMOVING TWO SCREWS THAT HELD IT INTO A STEEL BEAM....MY AFTERMARKET UNIT DOES NOT REACH THIS BEAM...HOW DO I SCREW IN MY AFTERMARKET JVC UNIT????</TD></TR></TABLE> Make a "L" bracket out of back bracing strap, [get it at your local car audio shop, mount it to the back of the JVC using the screw/bolt hole on the back of the HU, make sure that there is a hole/slot in the "L" between 6.5" to 6.75" from the back lip of the faceplate housing, [this is the lip the HU would slide up to in the sleave] you will find that the hole/slot will line up with the hole in the center of that brace bar that the stock HU was mounted to.
undisputed803
Audio / Security / Video
Jun 5, 2010 07:11 PM
AcInTheEg
May 2, 2007 04:05 AM
effinnwackk
Nov 12, 2005 09:28 PM
smithenhiven
10
Nov 26, 2004 09:00 AM
4doorRS5spd
Sep 6, 2002 08:29 PM
