I'v got a question
Old Dec 6, 2005 | 10:03 PM
chero112's Avatar
Default I'v got a question
I just bought a kicker L5 12 inch bran new I really didn't know what amp to go with so I went to a local store in my area that installes and sell's amp's, and the store manger told to get something small like a 500w or a 250 watta amp.... I bought a Rockford fosgate 250watt amp price was really high.tho........ A friend of mine told me that that amp was not going work right because of the speaker or some thing like that , that the speaker wont benefit form the amp at all..... Well it work ?
I not really looking for something loud just something simply and small and all this is going in too an integra if that help...
P.s I don't know nothing about systems!!!!
Old Dec 7, 2005 | 04:15 AM
t0p_sh0tta's Avatar
Default Re: I'v got a question (chero112)
What amp is it and what are the specs on the speaker? Dual 2 or 4 ohm?
Old Dec 7, 2005 | 10:01 AM
fcm's Avatar
fcm
Old Fart
The Kicker S12L5 is a 600W "RMS" DVC 2 or 4 ohm., [1200W max] a 250W amp can work but is realy underpowered for that sub, you will have to be very careful not to drive that amp into clipping.
BTW what R/F amp, [model number]?
As I said it can work, but a 600W amp would be better, or maybe your amp and 2 Kicker C8s 100W "RMS", [200 max] 94
Old Dec 7, 2005 | 11:19 AM
nsxxtreme's Avatar
Default Re: I'v got a question (fcm)
Clipping that amp would be about 500w, Assuming you dont stay in this condition to long and the speaker can handle 1200W it should be ok.
Old Dec 7, 2005 | 06:26 PM
chero112's Avatar
Default Re: I'v got a question (nsxxtreme)
I thank you guys alot for helping me out I just wanted to say....
Well the amp I bought the sales person told me that it just came out in stores
this is what is says on the box
Rockford Fosgate Power T3002
and the speca are:
channel 2
Per channel power 50x2 @ 4 ohms
100x2 @ 2 ohms
150x2 @ 1 ohm
300x1 @ 2 ohms Bridged/Mono
Total power 300 Watts
Bridgeable Yes
Crossover Variable 40-400Hz
High-Pass/All-Pass/Low-Pass
12dB/octave Butterworth
Tone controls Bass Control
Variable 35-70Hz remote ParaPunch Bass EQ 0db to +18dB.
Signal input Low level -
(1) pr RCA
Voltage -
High Level - n/a
Line output (1) pr RCA outputs
Phase control
Power input Connector - Block
Wire gauge - 4AWG power/ground
Built in ATC fusing
Speaker output Screw terminal barrier strip
Power supply topology MOSFET
Output topology MOSFET
Display Power - Top mount - LED
Thermal - Top mount - LED
Protect - Top mount - LED
Heatsink Type - Cast
Protection Yes
Remote control Included
Type - Wired
Controls - Bass
Class Class A/B
Marine use No
Specifications
Stereo/Mix mono Yes
Frequency response 20 to 20k Hz +/- 0.5 dB
Dimensions H 2.3" x W 12.8" x L 13.6"
Now I have no clue what all this means
And should I just return it and purchase a more powerfull one
Old Dec 8, 2005 | 08:12 AM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chero112 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes
Old Dec 8, 2005 | 08:49 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>Ditto that. 94
imadigitalgod
Audio / Security / Video
18
May 13, 2008 04:00 PM
deerman2701
11
Feb 14, 2008 05:27 PM
VietFoo
Dec 25, 2005 12:03 AM
NACvicSi
15
Oct 20, 2005 12:06 PM
