Integra Alarm Install
What year, on my 94 I made most of my tag ins at the OEM alarm plug, green plug, taped to harness, above fusebox, you can also go to http://www.bulldogsecurity.com for wire color and location.
or IM me if you need more help. 94
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/white |- |drivers kick panel *2 |
| POWER UNLOCK|black/red |- |drivers kick panel *2 |
| LOCK MOTOR|white/red | |driver kick panel |
| UNLOCK MOTOR|yellow/red | |motor in driver door |
| DISARM DEFEAT|yellow/red | |driver kick panel |
| PARKING LIGHTS +|red/black *3 | |grn plug above fusebox |
| PARKING LIGHTS -|green/yellow | |factory alarm (if equipped) |
| HEADLIGHTS|red/wht (low) 12awg|+ |steering column |
| DOOR TRIGGER|lt. green/red *4 |- |drivers kick panel *2 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|green |- |*6 |
| HOOD PIN|yellow/red |- |drivers kick panel |
|TRNK/HTCH RELEASE|blue |- |at switch *7 |
| FCTRY ALARM ARM|factory remote only | | |
|FCTRY ALRM DISARM|factory remote only | | |
| TACHOMETER|blue | |distributor *1 |
| SPEED SENSE|orange | |instrument cluster |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|gray or blu/grn |- |steering column |
| WIPERS|blue & blu/yel *5 |- |steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp |
| LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp |
| RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp |
| SUN RF OPN/CLOSE|grn/red - grn/yel |A |sun roof switch |
| RADIO 12V|white/blue |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA|yellow/green |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |radio |
| RF SPEAKER|red/grn - brn/blk | |radio |
| LR SPEAKER|blu/yel - gry/wht | |radio |
| RR SPEAKER|red/yel - brn/blk | |radio |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555U to bypass. *1 Also found in a 16 pin white or gray plug to the left of the fusebox. *2 In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch. *3 Also a male blade terminal is available in fuse box. *4 Looks like 14 awg wire but mostly insulation. *5 Use both and diode isolate each. *6 12 pin blue plug on top center of fusebox. *7 Trunk release only works with the doors unlocked.
Notes:
slikz714
Jul 21, 2007 03:27 PM
JLEK
Audio / Security / Video
May 22, 2007 09:04 AM
im_the_teacher
Jun 4, 2003 05:10 AM
