installing my capacitor HELP
Old Mar 16, 2008 | 05:24 PM
VTECcivicDOWORK's Avatar
Default installing my capacitor HELP
alright, im running a 1100W xplod with a 1000W kenwood amp.
ive got a 2farad tsunami cap that i bought from a pawn shop and it came with no wires, no instructions, just the cap.
it has been used so it should be charged correct?
i have no idea how to install it..
what do i need to install it? what wires? what gauges?
Modified by White Smoke at 10:00 AM 3/19/2008
Old Mar 16, 2008 | 07:01 PM
B18C_EJ8's Avatar
Although it's probably overkill for that amp, since it puts out nowhere near a thousand watts, 4 ga power wire from the battery goes to the positive terminal on the capacitor. Then, from the same terminal, a 4 ga shot (as short as possible) to the positive terminal on the amp. 4 ga ground from the negative terminal on the capacitor to a good chassis ground, as short as possible.
If the cap has a display, and there's an extra terminal on it, then you would splice into the remote wire going to the amp.
szczerbanator
Audio / Security / Video
May 25, 2009 09:07 PM
philosofy1
Dec 18, 2007 02:12 PM
95TEG
Oct 7, 2003 10:53 PM
Shadow Racer
10
Sep 17, 2003 06:48 PM
Ludester
Mar 13, 2003 03:27 PM
