installing dynamat
Old Nov 4, 2004 | 08:53 AM
rollin92's Avatar
Default installing dynamat
I own a 1992 Honda Accord Ex and I am planning on installing Dynamat Xtreme to the entire trunck and probably the doors also. It doesn't look like it will be very hard to install, but I've never done it before so I figured I would see if anyone had any pointers to make the installation go smoother.
I know there are cheaper products, but I'm getting a bulk pack for around $120 shipped, so I figure thats a pretty good price. I appreciate any help that you can give me.
Old Nov 4, 2004 | 10:48 AM
B18C_EJ8's Avatar
Easy. Remove panels/carpet. Cut Dynamat to approximate size. Peel paper backing. Stick Dynamat to panel. Rub on using hands, or preferably, a rubber roller. Reinstall panels/carpet.
One thing you'll need to pay attention to is the location of any push clips that hold your door panels on. If you put the Dynamat over the clip holes, it'll be tough to put the panel back on. Just pre cut (or stick a screwdriver through) the Dynamat so the clips will go through to the panel.
Old Nov 4, 2004 | 11:27 AM
kontai69's Avatar
Default Re: installing dynamat (rollin92)
In addition, make sure the body panel surfaces are nice and clean before applying the Dynamat. I used rubbing alcohol.
Old Nov 4, 2004 | 11:39 AM
georgelb's Avatar
Default Re: installing dynamat (kontai69)
here is a write-up of sorts I did on doing the doors...this is a very time consuming process if you do it right, but it makes a world of difference.
http://speed-society.com/forum...11672
Oh, and that bulk pack will not do the entire trunk and the doors unless you use it sparingly where it will help with resonance but not as much with roadnoise.
Old Nov 4, 2004 | 11:52 AM
GSteg's Avatar
it helps if the panels are warm or you heat them up. they stick better, at least when i did it.
Old Nov 4, 2004 | 10:12 PM
CarAudioPro's Avatar
Default Re: (GSteg)
man just to save you the trouble now, use a heat gun. if you don't your goign to have nightmares for year....lol, no but it makes it alot easier, and it activates the glue on the dynamat, and helps it stick longer.
Old Nov 5, 2004 | 05:33 AM
kontai69's Avatar
Heat is only needed to install Dynamat Original where "heating the material improves bonding and elastic moldability."
The newer Dynamat Xtreme is more pliable and the adhesive is super sticky, therefore "heating the material is not necessary."
For both materials, "the temperature of the mat and application surface should not be below room temperature during fitting."
All the above quotes are from http://www.dynamat.com
Old Nov 5, 2004 | 09:49 AM
Nyceguy17's Avatar
Default Re: (kontai69)
I agree in the clean the surafece with alcohol idea. There is no need to do the enitre door and trunk unless you are competing. I just did the area around my speakers and the panels in my trunk that had large flat surfaces that might cause unwanted resonation. No need to do it all, too much weight and that stuff smell bad in the summer if you have alot of it.
Old Nov 5, 2004 | 12:30 PM
Gumby99integ's Avatar
Get a heatgun or hairdryer to heat it up, b/c it will stick and you can streach it much more. And yes clean the surface and spend a good few hours putting it in.
Madvillian45
Audio / Security / Video
Apr 22, 2007 02:34 PM
txwylde
Feb 15, 2005 12:15 PM
SIcoup
Dec 28, 2003 06:22 PM
EXV62000
Apr 5, 2003 07:42 PM
JunkeeCrx
Jun 25, 2002 12:07 PM
