Install issues HELP!
Old Apr 5, 2009 | 12:33 PM
91sihatch's Avatar
Default Install issues HELP!
car: 2000 civic
alarm: compustar 900FMS
There are a number of issues i am having right off the bat
1) i can only program the one way remote, when i try to program the two way the alarm does not respond and it exits programming mode.
2) With the one way remote the car arms but the door locks do not lock and the alarm will not go off if i open the door when it is armed. It has an aftermarket stereo and the dome light does not turn on. Should there be two wires from the stock stereo to connect to make the dome light work? I taped into the lock/unlock wires in the blue harness of the control module under the drivers dash and the grn/red wires in the door sill for sensing.
3) I was testing sensors and when i set off the hood sensor the alarm went off as it should but i could not disarm it. I had to cut power to the alarm in order for it to stop. If i press the unlock button the alarm should stop going off?
Thats all for now. i have a feeling some more issues will pop up but i need to fix these first.
Old Apr 5, 2009 | 01:48 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Install issues HELP!
Make sure that the ground to the alarm is done correclty and is in good shape. i would also look into the attenna to make sure it is plug in correctly. Were did you get the alarm?
Old Apr 5, 2009 | 02:40 PM
91sihatch's Avatar
the ground is solid. sanded and mounted it to the frame.
i will check the antenna
the alarm was bought from a compustar retailer.
Old Apr 11, 2009 | 08:39 AM
91sihatch's Avatar
So i found out what the problems were
1)I have a faulty 2way remote
2) I tapped into the wrong lock/unlock wires and the dome light fuse was blown
byronl
Audio / Security / Video
12
Mar 27, 2008 01:51 PM
Nocturnal
Jul 21, 2007 08:35 PM
Kavehman
Oct 24, 2006 10:42 AM
blacK_Dc4
Aug 22, 2006 09:29 PM
tabo
May 13, 2003 07:03 AM
