infinity 7541a Q's
Old Jun 12, 2006 | 06:13 AM
Spicoli v 3.0's Avatar
Default infinity 7541a Q's
Just bought a 7541, 4 ch amp 4x111 @ 4ohms rms, and i'm hooking it up to my 5.25 jl coax, 50 rms for fronts and rca 250 rms 6x9 in the rear, since its 4x111, should i just crank the gain real low on the fronts to not blow them? or what should i do, this is to compliment my jl 500/1 with 2 pioneer 12's. So any advice on xover settings/whatever else i need ot know would be great
Old Jun 12, 2006 | 11:46 AM
8520's Avatar
Default Re: infinity 7541a Q's (Spicoli v 3.0)
Imo you should be running the crossovers in the deck instead of on the amp. As far as where, I'd set them at 120hz for the front and maybe 90hz for the rear. I run mine lower usually, but that's just me
You'll really have to play with the gain to figure out where you want it, but ideally you want your setup loud enough that you don't have to turn your deck or your amp above 75% imho
Old Jun 13, 2006 | 06:21 AM
Default Re: infinity 7541a Q's (a_s_ol_)
ok, so i went to hook it up using my old spade connectors, which i thought were for 8 guage, but the spade is too large, anyone familiar with this amp know the right size spade, i think it may just be the brand i used last time, but i'm not sure.
PS, the spades were used on the 2 channel amp i'm taking out, so i thought they should fit.
Old Jun 13, 2006 | 08:31 AM
found out the prob, i was using the 1/4 " opening, i need the #8 opening
BiG_DeE
Audio / Security / Video
Jan 24, 2009 11:48 PM
Cody2289
14
Feb 11, 2008 09:28 AM
Pworld
Apr 29, 2005 09:14 PM
Torridcivic
Sep 23, 2003 07:49 PM
The Alchemist...
Aug 13, 2003 08:25 PM
