Immobilizer Question
Old Jan 29, 2004 | 06:35 PM
icedaccord19's Avatar
Default Immobilizer Question
hey, i have a 99 accord that has a factory immobilizer, i had jus finish installing a viper 790xv in my car(well almost), i've read on this forum that the factory immobilizer can be bypassed, if thats true how long would it take a thief to bypass it, are we talking minutes/seconds, or hours. because i'm not sure if i want to get numerous kill switches if to bypass the immoblizer the thief has to go through hell to do it. thz
Old Jan 30, 2004 | 05:40 AM
HondaDriver4Life's Avatar
Default Re: Immobilizer Question (dray504)
You don't need numerous kill switches to bypass the immobilizer for your alarm to work properly. All you need is the proper immobilizer bypass device. Here are some recommended units.
555U from DEI (will require a spare key)
TBHA2 from Peripheral Electronics
PKH2 from bypasskits.com
When these devices are installed properly, a thief would still find it hard to compromise. It's all about the install and layering your security.
Old Jan 30, 2004 | 05:53 AM
Default Re: Immobilizer Question (HondaDriver4Life)
oh my bad that i didn't state what i was asking clearly, i know about the bypass kits that will allow you to use remote start without having to leave your key in the ignition, what i was trying to ask was, what if a thief wanted to steal my car or any other car with an immobilizer system, how long would it take him to defeat the immobilizer system and be able to drive away in my car. Please be specific, as far as minutes/seconds, or hours. thz
Old Jan 30, 2004 | 06:36 AM
I would say that a thief would look for an easier target. It would take too long to try bypass it w/o inside information on the particular car. For example, if you look at theft statistics on the Accord you'll see a down trend for the '98 and later models. 1998 is when Honda started using immobilizer circuits.
Cars stolen that have immobilizer circuits are usually done with the "inside help" from a dealer or someone who has access to making transponder keys. In this case, it would take seconds. Without this advantage, it could be bypassed but take too long. This is why I stated that layering security is important. The more obstacles for thief, the better. I also like to relocate the OEM immobilizer control unit.
Old Jan 30, 2004 | 08:12 AM
nOOber's Avatar
think about it for a second.
You have every wire a thief needs to start your vehicle all at one ( easy to reach)spot ( your R.S.).
Alls that's missing is breaking the steering wheel lock...
Not that I'm a thief or anything, but a vehicle with an R.S. would be seem to be a much easier target, than one with out...
Old Jan 30, 2004 | 09:07 AM
Default Re: Immobilizer Question (nOOber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nOOber &raquo;</TD></TR><TR><TD CLASS="quote">think about it for a second.
Not that I'm a thief or anything, but a vehicle with an R.S. would be seem to be a much easier target, than one with out...</TD></TR></TABLE>
That's why you have your alarm installed properly and NOT easy to reach. The car without an alarm (regardless if it has RS or not) or an immobilizer circuit is still the easier target. Think about it.....there's nothing extra to bypass.
Old Jan 30, 2004 | 12:24 PM
well even with a remote start in the car, and the thief finds the remote start harness and starter, ignition and whateva wire he needs to hot wire the car. would the immobilizer bypass be activated by the BLUE STATUS OUTPUT WIRE thats coming from the viper alarm, because if he hot wires the car and the immobilizer bypass isn't activated then the car still wouldn't start.
basically what i'm asking is if a thief hot wires the car would the immobilizer bypass be activated also. Thanks
Old Jan 30, 2004 | 02:38 PM
The immobilizer bypass will not be activated just by hot-wiring the vehicle. It needs the trigger from the alarm.
Old Jan 30, 2004 | 03:20 PM
aight thz, thats what i thought jus wanted to make sure.
Old Jan 30, 2004 | 07:11 PM
MyDamCivic's Avatar
Buuuuttttt......If a thief knew his shizz, and found the 555u...all he would have to do is ground the blue status output, and tap the red wire to constant 12v and he's in business.....sorry to add a dark cloud.
Old Jan 31, 2004 | 08:44 AM
Default Re: Immobilizer Question (MyDamCivic)
Once again, this is why installation quality is so important.
Old Jan 31, 2004 | 10:22 AM
Big Bang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyDamCivic &raquo;</TD></TR><TR><TD CLASS="quote">Buuuuttttt......If a thief knew his shizz, and found the 555u...all he would have to do is ground the blue status output, and tap the red wire to constant 12v and he's in business.....sorry to add a dark cloud.</TD></TR></TABLE>
if a thief foud the 555u all he needs to do is take the key out......
Old Mar 10, 2004 | 11:03 AM
TurboBumblBee's Avatar
Default Re: Immobilizer Question (The Converted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Converted &raquo;</TD></TR><TR><TD CLASS="quote">
if a thief foud the 555u all he needs to do is take the key out......</TD></TR></TABLE>
hahaha i had to laugh at that one...
Axatax
Audio / Security / Video
10
Apr 8, 2012 11:22 AM
vestalfootball72
13
Nov 8, 2007 05:59 AM
skingfreak
13
Dec 10, 2006 08:13 PM
B18EG6
Jun 22, 2006 08:35 AM
