Ignition Lock
Old Dec 13, 2004 | 09:05 AM
NiBlazed's Avatar
Default Ignition Lock
I tried posting this in the Accord forum, but couldn't get any replies. So ill try here
A couple months ago my accord got stolen, i got it back 2 days later. Now i never got around to it, and now im gonna have to get this fixed.
The whole ignition lock cylinder is just broken out. I can use my key to catch where the lock would go i guess. So now i got a used ignition with lock key and wires. But heres my other problem. One day i went to start my car with a screwdriver, and touched the circuit board thats in the steering colum and caused a spark. Since then my shifter locks and i gotta use the shiftlock release. Also my horn doesn't work, and neither does cruise control.
The circuit board was cracked when i got it back from the towing company, but my horn still worked, and i didn't have to use the shiftlock. I dont know about cruise control.
So i would like to know what that board is called, and if that would most likely be the problem, or /and if its the fuses.
Thanks alot
Old Dec 13, 2004 | 11:40 AM
vtec_yosh's Avatar
Default Re: Ignition Lock (NiBlazed)
I would go through and check the fuses under your dash and hood. The horn and cruise doesnt run off the same fuse. The shift lock, I believe, is electrical, so that also could be a fuse. Otherwise you may want to look at getting a whole new ignition system. Sorry I cant be more help
Old Dec 13, 2004 | 04:57 PM
fcm's Avatar
fcm
Old Fart
Default Re: Ignition Lock (fcm)
Sorry, I don't know what happend to my post, but, it sounds like one of the main fuses in the engine bay fuse box. 94
Old Dec 13, 2004 | 05:55 PM
NiBlazed's Avatar
Yea i didn't know there was a fusebox in the engine to. I checked before and found that the fuse for the horn and brake lights is the same one, and i know when i replace it the shiftlock problem will be fixed as well.
I also got my new ignition lock today. Mechanic says around $120 to install. Now i wanna attempt this myself. I see theres 2 plugs that connect to it, 1 i know has to be that little circuit board that is broken in the steering colum, i still need to find out what that board is exactly. The other is a much larger plug and im gonna say thats the main one, which would actually control the ignition.
I know theres the safety bolts, and i would have to use a saw to make cuts in the bolts, to take them off with a flathead.
Is that basically it?
Old Dec 13, 2004 | 06:50 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiBlazed &raquo;</TD></TR><TR><TD CLASS="quote">Yea i didn't know there was a fusebox in the engine to. I checked before and found that the fuse for the horn and brake lights is the same one, and i know when i replace it the shiftlock problem will be fixed as well.
Is that basically it? </TD></TR></TABLE>I thing you got it , the small circuit board may be for the key sense, if its way at the bottom of the ign.switch it may be the switch itself. 94
dustinrathke24
Sep 14, 2018 01:00 PM
Petite1234
Oct 28, 2014 04:28 PM
jimjonez
Dec 13, 2006 02:52 AM
qcktegls
Jan 9, 2005 03:52 PM
NiBlazed
Dec 10, 2004 03:45 PM
