i don't have memory help
Old Jul 7, 2004 | 04:42 PM
racin-type's Avatar
Default i don't have memory help
this is pissing me off having to set up my head unit everytime i start the car.
I have a 00 honda civic cx hatch. it did not come with a head unit from the factory but the wiring is there. however the connector is cut so i just have wires. I got it working but there is no memory. please can someone help with which wire does what. I got all the speaker wires out the way just the other wires i don't know about.
thanks
oh and i have a cheap *** sanyo head right now fi that helps.
Old Jul 7, 2004 | 05:00 PM
fcm's Avatar
fcm
Old Fart
Default Re: i don't have memory help (racin-type)
Your HU needs a unswitched power could be white with blue tracer in OEH radio harness, if you have no power there check the 7.5 amp fuse in fuse box under hood.
hope this helps. 94
Old Jul 7, 2004 | 06:33 PM
sammydhoff's Avatar
Just run a new wire from the 12 Volt constant wire in the ignition harness
The wire color is White (+)
I am a full-time audio/alarm installer, I have seen the wire go bad in some cars, so I just run a new one, hope this helps out.
Any questions email @ sammydhoff@yahoo.com
Old Jul 7, 2004 | 08:58 PM
fcm's Avatar
fcm
Old Fart
Default Re: i don't have memory help (sammydhoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sammydhoff &raquo;</TD></TR><TR><TD CLASS="quote">Just run a new wire from the 12 Volt constant wire in the ignition harness
Any questions email @ sammydhoff@yahoo.com </TD></TR></TABLE>
why not fix the problem, if its a fuse, evan if its not, repair it ,don't just add more wireing that can fail, and if you have to add wireing , run a fused line from the ign. output term. on fuse box all Hondas/Acuras have one, along with a acc. and a parklight in/out. I am also a full-time installer and have been for 30 years
94
Old Jul 7, 2004 | 10:34 PM
racin-type's Avatar
ok thanks for all the advice but those are not helping me.
my problem is that I'm not sure which wire does what. did my year civic not come with this unswitched power wire i have no clue. nothing is wrong with my fuses or my wires, its just not wired right and or missing a wire.
does anyone of you actually know what color wire does what. or sometype of wiring diagram for my car. if i can where can i get another connector piece for these wires?
thanks again
Old Jul 8, 2004 | 05:36 AM
spark plugs.
Guest
Posts: n/a
Default Re: (racin-type)
if you're really that much of a noob then sammydhoff is probably right, just run a fused wire from the battery to provide a 12 volt constant. that's your EASIEST solution.
Old Jul 8, 2004 | 06:46 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racin-type &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for all the advice but those are not helping me.
thanks again</TD></TR></TABLE>
the unswitched wire is white with a blue or a yellow tracer its no harder than that.94
Old Jul 8, 2004 | 02:45 PM
racin-type's Avatar
ok i finally got of my lazy *** and bought a multimeter to find out which wire does what. found out that i don't have a constant power wire.
can i just use a wire directly connected to the battery as my constant power wire? should there be a fuse inline on this wire? my hu already has a fuse is this enuff?
secondly can i bolt my amp to the back of my subwoofer box?
thanks for all the help.
Old Jul 8, 2004 | 09:07 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racin-type &raquo;</TD></TR><TR><TD CLASS="quote">ok i finally got of my lazy *** and bought a multimeter to find out which wire does what. found out that i don't have a constant power wire.
thanks for all the help.</TD></TR></TABLE>
If you cant find the constant you have a blowen 7.5 amp fuse in fusebox under the hood . yes you can just run a FUSED wire from battery.[ you need a fuse within 18" of battery]
YES you can mount your amp to box, it makes it so much easier for the crook
If it fits mount amp under pass. seat. 94
Old Jul 8, 2004 | 10:09 PM
racin-type's Avatar
hehe never thought about the thief and the sub box/amp. actually never thought about mounting the amp anywhere else. as you can see i'm a novice novice at this.
now that you mention it i have alot of room under my driver racing seat, but that seat is hot to sit in already. will mounting the amp under create more heat for me? i have no ac.
I will check for the blown fuse for my constant while i'm there gotta find out if my fuse for the dash lights are blown as well or the actual bulbs.
last question, is it better to have less wire from HU to amp or less wire from amp to sub?
thanks fcm, i think i woulda been good in audio if i didn't devote my time to the performance aspect of cars.
Old Jul 9, 2004 | 07:43 PM
fcm's Avatar
fcm
Old Fart
The amp will produce heat, mount it under pass. seat if you can, evan if you have to raise the back of the seat a little with washers/spacers and longer bolts.
The batt. is on that side of car I think, the shorter every thing is the better,shorter power wire, shorter RCAs, less wireing running to rear of car, just a 12ga speaker wire, just better all around. Think about it this way, mom phones you to tell you dad is getting a new TV come and get the 32" NOW or hes giving to george the guy next door, you unplug the banana jack pull out the sub box, your there on the other hand, RCAs power and ground trigger wire you get there just as pop is handing it to geo
the fuse for dashlights is in the incar fuse box,I think 94
tercelrcr
Audio / Security / Video
Oct 15, 2014 10:27 AM
sz9182
Apr 30, 2007 08:27 PM
Full Race A6
Jun 12, 2004 05:04 AM
94B18B1Teg
May 11, 2004 05:44 PM
Daniel_san
14
Oct 1, 2003 02:42 PM
