HU Setting help
Old Aug 20, 2005 | 10:39 PM
Orpheus1985's Avatar
Default HU Setting help
Ok, first off, I've got a Sony CDx5510 (I know, I know, I would have chosen differently ) And I'm adding subs. Well the audio out can be selected between Rear or Sub. The problem is, the Rear setting is for a power amplifier, and the Sub setting is directly to a sub, however, the Low Pass Filter only works on Sub mode. Since I'm using a power amp to power the subs, I would set it to Rear, right? But then I can't use the LPF. And as far as I can see by the diagrams, the Sub setting is for going directly to a sub with no external amp. Help me out, please!! Thanks
Old Aug 21, 2005 | 07:00 PM
Sorry, i really hate to bump so early, but I don't wanna screw anything up
Old Aug 21, 2005 | 09:02 PM
GSteg's Avatar
If you have a subwoofer preout, use that preout to connect to the amp that is going to power the subwoofer.
Do that, or you can use the Rear preout, but then you'll have to use the amp's lowpass filter (most likely it'll have it).
I would just use the subwoofer preout.
Old Aug 21, 2005 | 09:27 PM
yeah they call it Juice Boost, lol. That wont hurt anything sending signal to another amp instead of just a sub?
Old Aug 21, 2005 | 09:30 PM
GSteg's Avatar
well...if you use the subs preout on the amp, to power say your speakers, then the speakers will be low-pass (I'm assuming it does).
Not sure why you would want to low pass speakers unless you are using the mids as a dedicated midrange. lol
Old Aug 21, 2005 | 09:34 PM
well i mean the pictures show Rear going to an external amp then 2 6X9s but the Sub going to a sub with no external amp in between
Old Aug 21, 2005 | 10:54 PM
LudemanDan's Avatar
Default Re: (Orpheus1985)
I'd like to see the sub you're expecting to power directly off the head unit.
Dan
Old Aug 21, 2005 | 10:57 PM
No, I agree 100% with you, I just wanted to make sure because of the pictures
Old Aug 21, 2005 | 11:25 PM
LudemanDan's Avatar
The illustrator was probably just lazy.
Dan
BTW, nice Supra!
teejlc
Audio / Security / Video
Apr 26, 2007 07:52 AM
Will_H
Feb 19, 2007 08:05 AM
The Alchemist...
Aug 13, 2003 08:25 PM
ichibano
Feb 14, 2003 01:53 AM
frostwhite_92
Jun 2, 2002 08:37 PM
