Help! Audio Set-up question?
Old Apr 25, 2007 | 04:24 PM
teejlc's Avatar
Default Help! Audio Set-up question?
Hi, here is the set up im looking at for my hatch. Will this work?
Headunit = Alpine CDA-9856
50W x 4
4 Ch. Amp. = Alpine PDX-4.150
150W x 4
Front Speakers = Polk Audio MMC6500 Component system
10-125 watts RMS
250 watts Peak
Rear Speakers = Alpine SPR-13C
CEA-2031 Power Rating: 90 Watts
Power Handling Capacity (Peak): 180 Watts
Thanks so much!
Old Apr 25, 2007 | 04:35 PM
B18C_EJ8's Avatar
Yes.
BTW... If you're using a 4 channel amp, the power output on the deck is irrelevant since you'll be using the RCA outputs and not the speaker wires.
Old Apr 25, 2007 | 05:03 PM
94_DC4's Avatar
Default Re: Help! Audio Set-up question? (teejlc)
What car is this equipment going into?
Old Apr 25, 2007 | 08:19 PM
teejlc's Avatar
Default Re: Help! Audio Set-up question? (94_DC4)
1992 civic hatch
Old Apr 25, 2007 | 08:30 PM
94_DC4's Avatar
There are two ways that you can go about this. Youcould just use the amp for the componenet set in the front and connect the rear speakers to the HU or use all for channels on the amp and also power the rear speakers with the amp but have the gain for the rear set lower than the front.
Old Apr 26, 2007 | 07:52 AM
teejlc's Avatar
great! thanks for all the help!
JohnnyEF
Audio / Security / Video
May 19, 2010 04:59 AM
accord03
Jun 11, 2007 04:23 PM
JesseCRX
Aug 20, 2005 06:46 AM
shattergsr
May 25, 2002 10:53 PM
xJ.SLOTHx
Feb 14, 2002 11:12 PM
