How's this beginner setup?
Old Feb 25, 2006 | 07:42 AM
Azxster's Avatar
Default How's this beginner setup?
I do not care for sound quality, I just want bass.
http://www.cardomain.com/item/POWOV21600 (310 x 2 RMS)
or http://www.cardomain.com/item/POWLT14402 (300 x 2 RMS)
I think I like the LT14402 more? I don't need to pay for speaker inputs.
2 12" Infinity 1230w Subwoofers (e-Bay) (300 x 2 RMS)
8 Guage Wiring Kit
3/4" MDF, Sealed Enclosure
Am I missing anything? How is this setup for a beginner (not crazy for music)?
Old Feb 25, 2006 | 12:57 PM
fcm's Avatar
fcm
Old Fart
Default Re: How's this beginner setup? (Azxster)
I would look for a 1 x 600W - 800W rms into 2 ohm, [mono block sub amp] instead, or at least a 2ch amp that will make 600W - 800W into 2 ohms when bridged into 1ch, [must be stable at 2 ohms when bridged].
It does not appear that either of the amps you link us to is stable at 2 ohms when bridged, so you would have to leave them in 2ch mode and wire one sub to each channel, although this will work, it is not the most ideal way to power up a set of subs. 94
Old Feb 25, 2006 | 04:50 PM
Azxster's Avatar
Default Re: How's this beginner setup? (fcm)
Something like this
http://www.cardomain.com/item/ORI47400
With a pair of DVC Infinity 12"s?
Old Feb 26, 2006 | 03:03 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azxster &raquo;</TD></TR><TR><TD CLASS="quote">Something like this
With a pair of DVC Infinity 12"s?</TD></TR></TABLE> Yes. as long as the 12" Infinity's are DVC 4 ohms, all VCs paralleled will give you a 1 ohm load for the amp, also they should be no more then 300W continues each. 94
Old Feb 28, 2006 | 02:18 PM
8520's Avatar
I say 4 gauge and add a cap if you can afford it.
Old Mar 1, 2006 | 02:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: (got_no_sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got_no_sol &raquo;</TD></TR><TR><TD CLASS="quote">I say 4 gauge and add a cap if you can afford it.</TD></TR></TABLE> Ditto that, if your running a 600W amp and the power lead is longer then 4 ft you will need a 4ga power cable, an ANL fuse and holder, 4ga ground, and I would add a 4ga ground from the batt. to the cars chassis. 94
EdSales
Audio / Security / Video
Mar 10, 2010 06:35 AM
TheTealHatch
Sep 27, 2008 02:21 AM
calvinnguy3n
16
Dec 14, 2006 05:20 PM
CivHatchH22
Apr 12, 2004 09:21 AM
LuDeS
Nov 3, 2001 03:43 PM
