How to wire resistors?
Old May 9, 2006 | 03:06 AM
areem57's Avatar
Default How to wire resistors?
Can I use Crimp connectors to connect these resistors?
Crimp Connector
http://www.radioshack.com/prod...amily
Resistor
http://www.radioshack.com/prod...earch
Old May 9, 2006 | 05:33 AM
EBP_SI's Avatar
Default Re: How to wire resistors? (areem57)
no.
Old May 19, 2006 | 07:17 PM
siggy833's Avatar
You should be able to just twist and tape resistors and they would be fine if u do it right. Do not ever solder resistors! The heat may alter the resistance value!
Old May 19, 2006 | 07:25 PM
02 accord's Avatar
Default Re: (siggy833)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siggy833 &raquo;</TD></TR><TR><TD CLASS="quote">Do not ever solder resistors! The heat may alter the resistance value!</TD></TR></TABLE>
WTF?? If you know how to solder, then soldering resistors is no problem. But if you have no idea what you're doing and you heat the resistor for like 5 mins, then yes, you will change the value.
Using those connectors is fine also.
Old May 19, 2006 | 07:38 PM
siggy833's Avatar
Default Re: (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">
Using those connectors is fine also.</TD></TR></TABLE>
If thats the way you have learned than Ok. I just don't solder resistors jack....
Old May 19, 2006 | 09:09 PM
suspendedHatch's Avatar
Please don't ever say "twist and tape" in a positive way again. You might as well tell people to keep using duct tape to insulate their twist and tape wiring.
Solder them. We're required to. I always have an have never known of any problems. I always splint it against something too, even if it's a straight zip tie.
Old May 22, 2006 | 12:59 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siggy833 &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to just twist and tape resistors and they would be fine if u do it right. </TD></TR></TABLE>.....five months down the line, you will post up why your VTEC is not engaging...right?
Old May 22, 2006 | 02:22 PM
fcm's Avatar
fcm
Old Fart
Although a crimp can be pretty good, [when done right] it will never be as good as a solder connection, and soldering properly is not that hard, and as 02 accord said it would take a lot of heat a long time to do any damage, I also agree with most of the above posts, twisting together and taping is not a good way to do things, no matter if its wires or resistors.
If you do not have a soldering gun/pencil, you can pick up a 30W at RadioShack for under $8, it is all you need for small wiring... http://www.radioshack.com/prod...36&cp
Under $36 will get you a Weller 100W/140W gun, will cover most soldering in a car... http://www.radioshack.com/prod...36&cp either one will get a lot of use if you are going to work on your cars electrical yourself. 94
PS, what are you using the resistors for?
Flava
Aug 3, 2006 09:08 AM
2SlowDC
Audio / Security / Video
Apr 15, 2006 08:55 AM
.water
24
Dec 18, 2005 12:23 AM
Magic Wheels
Jul 17, 2004 02:03 PM
Del_Slowest
Oct 21, 2003 08:20 PM
