HOW TO INSTALL Glass break sensor???
Old Oct 12, 2007 | 07:47 PM
alscrx's Avatar
Default HOW TO INSTALL Glass break sensor???
I always wanted to know how to install additional sensors like a glass break sensor or tilt sensor. I have an alarm i bought from asianwolf.com Its called an 8000rs
There is no additional outputs for add on sensors so what do i do???
Alarm works great and has a super far range. Yes i did the install on my own.
Old Oct 13, 2007 | 08:55 AM
suspendedHatch's Avatar
Default Re: HOW TO INSTALL Glass break sensor??? (alscrx)
There's a diagram in the FAQ. The wire colors will be different because you're not using a DEI alarm, but the wire descriptions should be there. If not then here:
blue is hard trigger
green is soft trigger
red is constant
black is ground
orange is ground-when-armed
green on the alarm is the negative door trigger input
blue on the alarm is the negative trunk trigger input
Old Oct 18, 2007 | 02:48 PM
dookie11's Avatar
Default Re: HOW TO INSTALL Glass break sensor??? (suspendedHatch)
I heard Glass break sensors are not as good as Radar sensors, cuz the slightest sound like someone tapping on your glass or a key hitting the window can trigger it.. is that true, or can you turn the sensitivity down to a reasonable level to still prevent theft?
Old Oct 18, 2007 | 04:47 PM
Default Re: HOW TO INSTALL Glass break sensor??? (dookie11)
I've never had a problem with glass break sensors falsing. They have adjustable sensitivity, but I always just leave them at the factory default. I'm speaking of the DEI glass break.
Old Oct 18, 2007 | 05:27 PM
tha_badguy's Avatar
whats the default set at?
when i had one it would always false when cars with squeeky brakes & the trashman would come by...
Old Oct 31, 2007 | 07:46 PM
alscrx's Avatar
Default Re: (tha_badguy)
Need more desciptive help
Whats hard trigger?? Soft trigger???
Old Nov 1, 2007 | 09:49 AM
Default Re: (alscrx)
Hard or instant trigger means the alarm goes off.
Soft trigger or warn means the alarm chirps but doesn't go off.
Old Nov 3, 2007 | 07:08 PM
dookie11's Avatar
Default Re: (suspendedHatch)
RE: the glass break sensor
Everyday, some **** drives through the parking garage at my college parking garage, and the alarms on surrounding cars go off. which sensor is his stupid exhaust setting off, and if i were to have an alarm how should i go about those annoying "false alarms" besides shooting the idiot?
Pwnmeister
Audio / Security / Video
17
Oct 14, 2011 10:18 AM
hueyduey
Sep 1, 2008 06:12 AM
suspendedHatch
May 9, 2006 08:05 PM
staticrex
Oct 27, 2004 12:05 PM
itsJDMyo
Feb 18, 2004 01:18 PM
