How important is the head unit?
Old Mar 24, 2004 | 03:52 PM
Skuzzy's Avatar
Default How important is the head unit?
Hey guys, I have an older sony head unit (probably 5 years old), that I like because it looks very stock-ish. However, does the sound get much better if I upgrade to a new unit?
I have boston acoustics in the rear, and some pioneers in the front - with a Jl 10 and MTX in trunk.
Old Mar 24, 2004 | 03:54 PM
proglife's Avatar
Default Re: How important is the head unit? (Skuzzy)
That's an ES, the circuitry is probably pretty decent. If it's not broke, I'd hold on to it until it breaks.
Old Mar 24, 2004 | 06:59 PM
Goatsterrman's Avatar
Default Re: How important is the head unit? (proglife)
I would say that it depends on what your are planning on replacing it with. If you are going to an entry level peice, then I'd suggest staying with what you have now(assuming it works properly). If you want to spend a alittle money and get a really nice unit, the you will definately notice a difference. I would recommend waiting about a month and getting one of the new Eclipse units coming out. I recently went to Eclipse's new product training and the new units are gonna be really nice.
Old Mar 24, 2004 | 08:09 PM
erikiksaz1's Avatar
Default Re: How important is the head unit? (Goatsterrman)
Will the new Eclipse units have removeable faceplates?
Old Mar 24, 2004 | 11:10 PM
ATF Kuk's Avatar
Default Re: How important is the head unit? (erikiksaz1)
i dont think eclipse will have detach anytime soon since they incorperated their own security network.
Old Mar 24, 2004 | 11:23 PM
rodimus's Avatar
Default Re: How important is the head unit? (ATF Kuk)
jdm clock blocker!
(kidding)
Old Mar 25, 2004 | 12:03 AM
vteg's Avatar
New User
Eclipse should get rid of esn and just do detachable.
I have had more cars stolen than headunits, so maybe it does not make a difference.
Old Mar 25, 2004 | 04:43 AM
HNDAPWR's Avatar
Default Re: How important is the head unit? (vteg)
The headunit is the first and most important link in a chain. The chain is only going to be as strong as it's weakest link. If you use a old, crappy head with a crappy signal, you are only going to pass on a **** signal to the amps or speakers. Amplifying an already shitty signal is never good.
Old Mar 25, 2004 | 07:34 PM
HiRevn's Avatar
Default Re: How important is the head unit? (HNDAPWR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HNDAPWR &raquo;</TD></TR><TR><TD CLASS="quote">The headunit is the first and most important link in a chain. The chain is only going to be as strong as it's weakest link. If you use a old, crappy head with a crappy signal, you are only going to pass on a **** signal to the amps or speakers. Amplifying an already shitty signal is never good.</TD></TR></TABLE>
This is too true. Pretty much all the components of a system have to be good (or at least decent). A top of the line HU with crappy speakers will not sound very good and vice versa. If what you have right now works okay, I would just stick with it. BTW, your car looks like it's in pretty good shape. Keep it up!!
Old Mar 25, 2004 | 11:25 PM
Default Re: How important is the head unit? (HiRevn)
100% correct, It is truely only as strong as the weakest component. And this includes wiring, there really is a reason to use suffecient wire size, on both power and speaker connections. And those really expensive rcas aren't that expensive because they look cool.
But I will say that it makes no sense to get a crappy headunit. If nothing else it's in the center of you dash so it's something you should be proud of when people see.
Old Mar 26, 2004 | 12:27 AM
PlastikOwl
Guest
Posts: n/a
the new ones play mp3's
Old Mar 26, 2004 | 02:52 PM
mr poo's Avatar
Default Re: How important is the head unit? (PlastikOwl)
the mp3's you find on the web today are very low quality and not consistent. . . if mp3's are important to you i would consider THAT your weakest link
Old Mar 26, 2004 | 02:53 PM
PlastikOwl
Guest
Posts: n/a
Default Re: How important is the head unit? (mr poo)
the thousands upon thousands I already have are good enough for me.
Old Mar 26, 2004 | 02:57 PM
mr poo's Avatar
but not good enough for people who are **** about sound quality
Old Mar 26, 2004 | 02:59 PM
PlastikOwl
Guest
Posts: n/a
apparently not...I myself think the human ear can really only go so far... whats the next step? stuff a goddamn brass band in your trunk for live music?
Old Mar 26, 2004 | 03:02 PM
rcurley55's Avatar
New User
yeah, MP3's are utter crap for SQ
BTW, I've seen people do very well in SQ competitions with factory headunits - some modified, others not. It all depends on the entire chain - most people's weakest link is their install not their equipment.
Generally speaking, people's installs are poor at best IMO. Again, generally speaking...
Old Mar 26, 2004 | 03:47 PM
mr poo's Avatar
mp3's are just plain inconsistent, there are so many ways you can screw up an mp3, you can rip it from a cd using questionable software, heck, some people even record things off their tv and turn it into mp3's.
take 10 random mp3's and play em in your car, if you're picky about sound you'll think that you have different sound settings for almost all of those songs. they just sound different because they were recorded different.
not trying to start a furious debate, just statin my opinions through experience
Old Mar 26, 2004 | 04:26 PM
PlastikOwl
Guest
Posts: n/a
they have software that fixes that somewhere...trying to find out if I have it stashed somewhere.
Old Mar 26, 2004 | 04:54 PM
vteg's Avatar
New User
The headunit is not the weakest link in most systems. The speakers are.
Old Mar 26, 2004 | 05:08 PM
Lou_Cypher's Avatar
ty vteg
the speakers are the foundation for ANY system
your head unit is fine if you dont want to spend any $$$
even though Sony is (ugh)
streetlegal816
Acura TL, RL & ZDX
Nov 14, 2007 05:51 PM
The Alchemist...
Audio / Security / Video
Jan 11, 2005 06:37 PM
v2 Power
78
Sep 7, 2003 08:26 PM
lil russia17
14
Feb 4, 2002 03:34 PM
Veritas-Aequitas
Dec 21, 2001 12:18 PM
