How Hard is it to...
Old Jan 19, 2004 | 08:25 AM
DriveSideWays's Avatar
Default How Hard is it to...
How Hard is it to Install a alarm, no remote start and window roll up and down b/c best buy and circuit city want about 600 for everything. is it worth the time and diffuculty? i just wanted to know b/c i dont want my car to get stolen and i live in philly so cars r missing like 5 mins. thanks
Old Jan 19, 2004 | 05:52 PM
brads94accord's Avatar
Default Re: How Hard is it to... (DriveSideWays)
how hard is it to ----------> drivesideways
well its really not that hard just time consuming and there are some pretty tight areas to work in. check on the web and do a search for wiring diagrams so you know which wires to tap into. also this has been discussed a few times before. make sure you have plenty of daylight (or a few really good lights). a razor blade, some wire strippers, smash caps, i would recommend soldering, i didn't do it with mine but i would recommend it. and i know if its DEI, they have installation manuals you can't print off the website.
Old Jan 19, 2004 | 07:54 PM
vteg's Avatar
New User
Default Re: How Hard is it to... (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to ----------&gt; drivesideways
.</TD></TR></TABLE>
Easy depending on how long you want to do it
If you have installed your own car audio system before then you can probably do an alarm. You will need a dmm in addition to the stuff previously listed.
Old Jan 20, 2004 | 11:00 AM
wiked7thgen's Avatar
installing a alarm is pretty easy, remember alram is all in the install, if the install is shitty, your alarm gonna function shitty
Old Jan 20, 2004 | 12:19 PM
hadehatch's Avatar
if you know a little bit about electronics and you can figure it out it makes the job much easier.. but what you want to do can be done just by following a few simple steps or a wiring schematic... check out http://www.the12volt.com they have pretty much everything you need to know there.. hope this helped..
acuracy r
Audio / Security / Video
Apr 19, 2004 09:43 AM
mattduskater
Oct 2, 2003 04:39 PM
Escabar
81
Sep 26, 2003 04:12 AM
drumking15
16
Jul 19, 2003 05:38 AM
MyBigNut
40
Oct 4, 2002 10:49 PM
