How do I remove the headunit in an EG?
Old Feb 9, 2008 | 03:14 PM
CtrRacer96's Avatar
Default How do I remove the headunit in an EG?
I just bought a 95 EG off of a guy and the headunit that he put in it isn't completely wired up. I removed glove box to see if there was any way i could get to it from there, and I removed the console under it the headunit and climate control, and from there I tried to push it from the back but it won't go anywhere without breaking something on its way out. Any know to to get it out without removing the whole dash?
Old Feb 9, 2008 | 03:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: How do I remove the headunit in an EG? (CtrRacer96)
It sounds like he has installed a back support, and if he has done it properly it is connected to the stock back support brace, this may help... http://www.installdr.com/Insta...7.pdf
The other possibility is, if it is like most aftermarket HUs, the HU is "locked" into it's mounting cage, and the cage is mounted into the stock din opening, if it is an aftermarket HU you are going to need a set of release "keys".
What is the make and model number of the HU? 94
Old Feb 9, 2008 | 03:25 PM
CtrRacer96's Avatar
Default Re: How do I remove the headunit in an EG? (fcm)
Its a JVC HDR1
Old Feb 9, 2008 | 03:49 PM
fcm's Avatar
fcm
Old Fart
That model number does not come up on the JVC site, it should be KD- something
Is it a newer or older HU?
Is it CD, Cass. or multimedia?
Is it a marine HU?
Probably a KD-HDR1... http://resources.jvc.com/Resou...A.pdf page 2, if you do not have the "keys" a set of thin butter knives should work.
Old Feb 9, 2008 | 04:02 PM
CtrRacer96's Avatar
Ya it is the KD-HDR1.
Old Feb 11, 2008 | 01:35 PM
NVturbo's Avatar
O.G. triple O.G.
If it held with the stock bracket support, you can reach the screws/bolts from underneath the H/U. Removing the ashtray console will do the trick. Just make sure that you don't skin any of the wires or you will end up with a blown fuse.
polyhonda
Jan 21, 2013 05:33 PM
X93siX
Oct 29, 2010 01:55 PM
brewski
Oct 26, 2009 06:12 PM
Mixmasta
May 16, 2007 08:56 AM
Trbospnkr
Jan 29, 2004 04:24 PM
