how do i install a sub?
Old Jul 8, 2007 | 11:50 AM
Bulli Kid's Avatar
Default how do i install a sub?
i want to install a sub in my 07 civic since it has 4 wimpy speakers only.
so here is the story. my bro had 2 12's in a box. he cut the box in half and put that part in his car. The other half is what i will be using. Its a wolfentech sub 1000 watts 500 rms i belive. ( i dont know what rsm means) but the sub works great on his car with a 600 watt amps by kenwood.
so yah i need to know the basics i got it pretty much figured out but i need to be sure of what other stuff i need.
i have to purchase this i belive to install amp and then the radio to amp right??
http://www.crutchfield.com/S-R...L#Tab
so power goes to positive battery then i hook up the fuze somewhere in a safe place. run the wire threw the firewall and back into the amp. then connect sub wire to box right? what gauge wire should i use? is 18 ok? next i think i have to run 2 wires from the amp to the headunit ( i am using the stock civic lx headunit) can i still hook up the sub to it?
and after that is that all ?
ps. i will try to look for a used amp because im on a budged and want this to work for cheap thanks
Old Jul 8, 2007 | 02:55 PM
B18C_EJ8's Avatar
You've got it pretty much covered, but you'll also need a wire run back (connected to any switched 12v source) for the remote wire.
You'll also need a line out converter, which you can connect at the rear speakers, since it's easier than pulling the head unit.
Old Jul 8, 2007 | 07:37 PM
EBP_SI's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">You've got it pretty much covered, but you'll also need a wire run back (connected to any switched 12v source) for the remote wire.
You'll also need a line out converter, which you can connect at the rear speakers, since it's easier than pulling the head unit.</TD></TR></TABLE>
unless your amp has high level inputs of course.
Old Jul 9, 2007 | 02:34 PM
Bulli Kid's Avatar
Default Re: (EBP_SI)
what kind of amp should i look into getting? what wats and such? my sub will be 1k watt and max rms is 500
Old Jul 9, 2007 | 02:47 PM
B18C_EJ8's Avatar
If the sub is truly 500w RMS, then you should be looking for an amp capable of delivering at least 500w RMS.
Is that sub single or dual voice coil? What's the ohm value on the sub??
Old Jul 9, 2007 | 05:32 PM
Bulli Kid's Avatar
i have a Volfenhag 12" sub its 500 watt rms and 1000 watts max power.
its dual voice coil and has 4 ohm. Ps what power wire gauge should di be running?
pps i need a Line Level Converter how do i go about installing that?
Old Jul 10, 2007 | 04:11 AM
B18C_EJ8's Avatar
Volfenhag... LOL... I remember a guy from my Best Buy days coming in with a charred trunk because his Volfenhag subs burnt the expletive up...
Anyways... As stated above, If the sub is truly 500w RMS, then you should be looking for an amp capable of delivering at least 500w RMS.
Old Jul 10, 2007 | 01:01 PM
Bulli Kid's Avatar
but what gauge would the cable be for 500 rms?
Old Jul 10, 2007 | 05:05 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (Bulli Kid)
Look at the sticky above. It has everything on power wire issues. If you need a loc pay for shipping and you can have a free one. Other then that youhav everything down right
Old Jul 14, 2007 | 01:03 PM
Andrew12's Avatar
16 gauge is pretty much the ideal wire for -1200 rms
ITR_dreams
Audio / Security / Video
Jan 26, 2005 05:04 PM
XViEtBoiX
Jan 21, 2004 05:36 PM
JOMO
Jun 17, 2003 09:22 PM
Understeer
Apr 30, 2002 03:26 PM
Zulu888
Aug 31, 2001 07:23 PM
