How do i find the code for my cd player
I have a 04 tsx and the previous owner disconnected the battery so i need the code so i can hear some music...Acura told me it will be almost $100 for them to do this
Pull the HU, get serial number off label, ha and proof of ownership of car go to service dept. and ask for code, it should be free, the $100 would be for them to R&R the HU.
If the Acura dealer you go to will not get you the code for free, find another dealer and send off a letter of complaint to Acura/Honda main office.
It takes the counter guy at the service counter less then 30 sec. to pull the code from their computers, so there should be no charge. 94
You can also try a Honda dealership if you don't have an Acura one in town (ours it cable to do it, and it's a straight Honda since they were going to look into doing Acura, but Acura would require a completely different building/showroom which they don't have the a lot big enough to do)
You can cheat and look up your car on MetraOnline.com
Then, click a dash kit for your car, and on that page click the link for "Product Instructions" or whatever the link is
There is no Metra kit for the 04 TSX... http://metraonline.com/vfg so the above ^^^ will not work.
If you are going to work on your car yourself, you should spend the $20 for a Haynes manual, it will pay for itself in no time.
Radio bezels/trim and dash/console trim can be very tricky, but if done in the correct order, they will be relatively simple.
I have not done an 04 TSX so I can't even give you an idea of where to start, all I will say is don't start pulling/prying things untill you know what needs to be done and in what order. 94
If you call the general honda 800 number, there should be an option get codes for radio. This worked for me in my 2002 accord. I can't remember what they asked for, but they did give it to me over the phone. Hope this helps!
I have a problem with my honda element 2004, i changed the battery and now the radio is not working, needs a code, i did not find the code in all the car.
the VIN is 5J6YH185X4L010678
the radio number is 21084426
thanks
thanks
Delete one of your double posts, the answer to your post is the same, go to the dealer, no one here will give you the code, if someone does they deserve a swift kick in the ***.
There is a reason for the code, it is a security measure, if all you have to do is go onto the internet to get it, it would not be much of a deterent to a crook. 94
BigBlockCRX
Audio / Security / Video
Jan 4, 2004 03:29 PM
dustin
Sep 12, 2001 10:48 PM
