Hooking up strobe lights to alarm
Old Jan 23, 2006 | 05:27 PM
skrewdriver88's Avatar
Default Hooking up strobe lights to alarm
I was reading some post and a few people said that they have installed strobe lights in there car that is wired up to the alarm so it will start strobing when the alarm is set off. I was wondering where they bought the strobes from and what wire did they use to tap into the alarm brain on a Python 460HP?
Thanks
Old Jan 23, 2006 | 05:40 PM
White95SiHB's Avatar
Default Re: Hooking up strobe lights to alarm (skrewdriver88)
Wal-Mart, Autozone, Kragen, and Pep-Boys should have some. However, they're not as bright as the strobes seen on pacecars, police cars, and fire trucks. They have 2 wires, (+/-). If you want them to turn on when the alarm is tripped, the only thing I can think of is to tap the strobe wire into the wire connected to the siren.
Old Jan 23, 2006 | 06:28 PM
suspendedHatch's Avatar
Default Re: Hooking up strobe lights to alarm (White95SiHB)
Probably want to use a relay. Siren wire to 86, 85 chassis ground (no thicker than 18 gauge wire). - on strobe to chassis ground. 87 to constant 12V, fused, 30 to + on strobe. Haven't done it myself though.
Old Jan 23, 2006 | 07:18 PM
Actually I have this kit here: http://www.streichers.com/Prod...0CCCC. It is the ones that the police use so it should be bright
Old Jan 24, 2006 | 10:24 AM
MLD211's Avatar
Default Re: Hooking up strobe lights to alarm (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Probably want to use a relay. Siren wire to 86, 85 chassis ground (no thicker than 18 gauge wire). - on strobe to chassis ground. 87 to constant 12V, fused, 30 to + on strobe. Haven't done it myself though.</TD></TR></TABLE>
Yep, that would work. If the strobes are negativly activated then 87 would go to ground rather than 12v+ and the the strobe - activation would go to 30.
Old Jan 24, 2006 | 05:09 PM
Default Re: Hooking up strobe lights to alarm (MLD211)
What size fuse should i put in?
Old Jan 24, 2006 | 06:38 PM
asleepz's Avatar
http://galls.com/category2.htm...=2699
Exspensive, but if your looking for emergency vehicle strength. http://www.galls.com is the way to go.
Old Jan 25, 2006 | 04:42 AM
B18C_EJ8's Avatar
Galls is overpriced. You can get the same equipment on eBay. When I got my Whelen police strobe kit, I saved like $200 buying on eBay.
Old Jan 25, 2006 | 05:09 AM
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Galls is overpriced. You can get the same equipment on eBay. When I got my Whelen police strobe kit, I saved like $200 buying on eBay. </TD></TR></TABLE>
Do you happen to remeber who the seller was? How do you like it?
Old Jan 25, 2006 | 05:43 AM
B18C_EJ8's Avatar
No idea. Was like 3 years ago.
Actually, that link above (Streichers) is a good price. That's the one I have as well. I got 2 extra strobe tubes and cables for about the same price on eBay.
Good link.
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
flatblack-h22
Jul 12, 2006 10:30 PM
Unjockable
Mar 8, 2005 12:06 PM
superthug
Oct 27, 2003 05:28 PM
RedDawg
Oct 5, 2001 10:34 AM
