hood relocation cable for civic Ek
Old Jun 11, 2008 | 07:05 PM
ekinshuya's Avatar
Default hood relocation cable for civic Ek
anyone have tutorial and pictures on how to do hood relocation cable for a civic 96-00 EK? I know there is one for the Integra but the hood release tab inside the civic is different and i want to make sure and do it right
Old Jun 11, 2008 | 07:40 PM
JasonGhostz's Avatar
Default Re: hood relocation cable for civic Ek (ekinshuya)
https://honda-tech.com/zero...89671
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">For 96-00 Civic Models (with a "Fused" Handle/Cable Assembly (74130-S01-A01))
Phillips Head Screwdriver
12mm Socket & Ratchet (& Torque Wrench)
Flathead Screwdriver or Panel Popper
Pick
- Remove Bumper
- Remove Fender Liner
- Remove Lower Dashboard Cover
- Remove Kick Panel
- Detach Latch from the vehicle
- Detach Cable from Latch
- Undo Plastic Guide Clips for the Cable (5 of them, I think...) and remove them from the Cable (they split in half without breaking)
- Feed Cable back into the Cabin
- Poke a hole in a Firewall Grommet (take necessary precautions)
- Feed Cable back into Engine Bay through the hole you made... It might help to have a Wire Puller, or a piece of Coat Hanger to pull it into your EB.
- Route Cable away from Moving and/or High-temp parts (as best as you can), all the way back to the Latch area.
- Attach Cable to Latch
- Attach Latch to vehicle
- TEST YOUR ****!!!!!
- After confirming everything works the way you want it to, reinstall the Kick Panel, Lower Dashboard Cover, Fender Lining, and Bumper.</TD></TR></TABLE>
Old Jun 15, 2008 | 04:24 PM
ekinshuya's Avatar
ANYONE HAVE PICture on the area where you POKE a HOLE to bring cable inside the car? FOR 96-98 HATCHBACK only please
Old Jan 3, 2009 | 09:23 PM
cloud2kz's Avatar
Anyone try this for an EK?
from this picture it looks like the cable needs to be disconnected from the latch, unlike the integra write up.
http://www.hondaautomotiveparts.com/...&catcgry5=HOOD
Old Mar 8, 2017 | 06:22 PM
petr0lb0mb's Avatar
Thanks JasonGhostz for the instructions. The operation went smoothly and now I'll feel a little bit safer on the odd occasion that I park on the street.
Originally Posted by JasonGhostz
FeelTheBass
Feb 8, 2015 09:42 PM
Legion_2
10
Jan 29, 2009 04:31 AM
cloud2kz
Jan 5, 2009 03:04 AM
Elmo1968
Apr 1, 2007 03:19 PM
tech125
Feb 25, 2003 02:33 PM
