Help with sub
Old Aug 27, 2004 | 11:01 AM
esca's Avatar
Default Help with sub
Hey, i had my car at the mecanics a few days back, and he was messing with the ecu, because my car wasnt starting.. so i took it to another place, and the car starts running (blew a fuse) ended up buying a dist and almost a new ecu because the other mechanic trying to make some $$ off my ***.. but going through bbb and filing complaint to aaa about their shady buisness.. anyways this is wahts going on
before i took my car to the mechanics, the sub (jl 12 inch) and the amp (mtx thunder something?) work perfectly fine, but after i turn on my system, the sub does not produce bass.. i dont think the amp is connected somewhere, but since i bought the car with these components already in there, i dont really know how to work the wiring, does anyone have pictures or diagrams or most helpful, ideas on how to fix this? (does it have anything to do with the ecu?)
thanks in advance
Old Aug 27, 2004 | 11:35 AM
arrivalanche's Avatar
Default Re: Help with sub (esca)
the only thing i could imagine that happened was that they might have pinched your remote turn on lead comming from your radio, or maybe disconnected the power from the battery when they were working on it. if you have a test light or a meter check to see if you have power at both your 12V constant and your turn on lead when your radio is on.
pjr710
Audio / Security / Video
21
Aug 6, 2008 02:48 PM
dth0ng69
Jun 29, 2008 04:44 PM
eskimo10
18
Nov 16, 2007 09:06 AM
ekcivic9
Sep 3, 2006 06:36 PM
93civdx
Dec 22, 2002 11:06 AM
