HELP! Re-Wiring Security System After Theft
Old Oct 16, 2005 | 01:38 PM
smallttocs's Avatar
Default HELP! Re-Wiring Security System After Theft
My integra was recently stolen and re-covered. the thieves got into the car alarm system. On the security box they cut two wires both labeled "Trig." It is a Chapman Car alarm. the car does not have any power when the key is turned.
anyone who knows where the wires go please help me out!
Old Oct 17, 2005 | 12:01 PM
smallttocs's Avatar
Default Re: HELP! Re-Wiring Security System After Theft (smallttocs)
bump
Old Oct 17, 2005 | 12:39 PM
MLD211's Avatar
Trig Im going to assume means trigger? And those would be input wires. There for having no effect on your cars power. If the car has no power and the battery is good check all your fuses and make sure no other wires under the dash are cut. Test the 12v constant wire in your ignition harness if it has power then theres may be somthing wrong with your key cylinder. If it doesnt theres has to be a blown fuse or a cut wire some where. But I will need more info. Make model? How did they steal the car? Hot wire? Jam a screwdriver in the ignition? or what?
Old Oct 17, 2005 | 12:40 PM
fcm's Avatar
fcm
Old Fart
I don't know what they would be plugged into, unless they are connected to relays that are wired as NO, [normally open] and the one of the relays is on the ign. wire from the ign. switch.
Normally "trigger" means an input trigger, like door trigger or hood/trunk trigger.
Disabling relays are normally wired as NC, [normally closed] so unless "triggered" by an alarming, alarm would be closed, however there are some alarms that you can program for NO or NC operation.
I would check the main fuses. 94
Old Oct 18, 2005 | 04:07 PM
smallttocs's Avatar
Default Re: HELP! Re-Wiring Security System After Theft (fcm)
the trigger wasn't the problem. it turned out to be a weak battery. thanks guys
erickcanales93
Honda Civic (2006 - 2015)
Oct 29, 2013 08:34 PM
urboymanny06
Audio / Security / Video
10
Jan 14, 2009 05:54 AM
AreJay126
14
Aug 22, 2005 10:38 PM
tweak
Jul 7, 2005 06:43 PM
