help a porting noob?
Old Aug 28, 2003 | 06:16 AM
GroundZer0 336's Avatar
Default help a porting noob?
ok well im in the process of building an enclosure for my crx and ive decided to go ported. ive used a enclosure calculator thing and it says ive got around 8 ft to play with, but it doesnt sound right to me for some reason. BUT i just ordered one of the 2 15inch rockford hx2's im puttin back there. i want there to be a single chamber and a single port. now for the port after i figure out what to tune it to (what should i by the way, this is for daily driving) do i just cut a rectangle and thats it, or do i have to build a chamber of some sort? i know you guys know your stuff about porting, and i know nothing.
Old Aug 28, 2003 | 06:50 AM
t0p_sh0tta's Avatar
Default Re: help a porting noob? (lowlife4life)
You've got one hell of a learning curve ahead of you.
http://www.diysubwoofers.org/prt/
http://www.jlaudio.com/tutorials/ports/index.html
http://www.termpro.com/cgi-bin...14688
Port size calculator
Old Aug 28, 2003 | 07:19 AM
Default Re: help a porting noob? (t0p_sh0tta)
i knew you would help me topshotta ha. thanks for the links!
Old Aug 28, 2003 | 09:06 AM
ok well im learning alot about ports and all so i think ill have a good idea of how to do it by the end of the week. but what should i tune it to for everyday driving w/ alot of rap and low bass?
are the 15 hx2's (not power) pretty good in ported box?
Old Aug 28, 2003 | 04:22 PM
vteg's Avatar
New User
Tune it between 30 and 35.
Does your amp have a subsonic filter?
Old Aug 28, 2003 | 04:51 PM
vteg's Avatar
New User
Default Re: help a porting noob? (vteg)
I never realized you were orgasmobilecrx
I knew that avatar looked familiar.
Old Aug 28, 2003 | 08:06 PM
yup same person, but now i guess my threads suck? ha o well. i was waitin for you to get in here and help me cuz i know you and topshotta know your ish about porting.
o wait are you talkin about on termpro? or here
Old Aug 28, 2003 | 08:19 PM
ok well i just looked at my measurements for the box and theres no way in hell thats how big it is, it might be 6cu ft. that stil doesnt sound right for being the trunk of a crx.
since i am making everything but the top of the box out of fiberglass (so i can get every little bit of area i can) will it hurt the performance of the ported enclosure? i hope not i really need some lows. loud ones too!
Old Aug 28, 2003 | 08:55 PM
vteg's Avatar
New User
If you give me the dimensions of your trunk i can see what is possible. I don't know how you are going to get 2 ported 15's in there without a wall
First of all which do you have, the punch or power hx2? (why does rf give to subs the same name). Post the t/s parameters and recommended box size. I am assuming you have 6 cubes internal to work with. With a port big enough to have no port noise on 2 15's your port may easily consume 1 cube. I check rf's site and cannot find specs on that sub.
Old Aug 28, 2003 | 10:01 PM
theyre just the punchs. but i was talkin to a guy on termpro and he said hes got 2 15s in a 6ft enclosure and they hit really hard. so good enough.
hhaa no wall. i know they can fit, i know someone that put 3 12s ported in the same part im puttin the 15s. i had some 15s before but not ported.
uhh well i was messin aorund on some calculator things and im gettin around 6 cu ft but thats just an estimation, im not even done w/ the box yet. but it was tryin to get it at 6 ft tuned to 30 hz. the calculators said i could do a 6x11 port would that even work, i mean, thats a bigass hole. haha
Old Aug 28, 2003 | 10:03 PM
o yeh and recomended ported enclosure is like 2-4 ft for one sub. i saw some more stuff on the site but i forgot it
Old Aug 28, 2003 | 10:37 PM
vteg's Avatar
New User
66 square inches, that is a girly port. Check out the box I was building for my xxx.
Anyway. You have 6 cubic feet internal space. Subtract .46 for the 2 15's. I come up with a port length of 25 inches at 66 square inches to tune you to 35. You box volume will be 4.6 cubic feet after sub and port displacement.
Is that what you were looking for
Old Aug 28, 2003 | 10:42 PM
well another problem im having is that the top of the enclosure is only 37.5 " wide so i dont know how im gonna fit 2 15s and a bigass port.
Old Aug 28, 2003 | 10:46 PM
i think what im just gonna end up doing is waiting until i have both 15s and amps and put them in the box sealed, before i make the fiberglass baffle, cuz then i can play w/ it and see if aport will fit and see how it sounds and whatnot.
i still need to learn alot more about it anyways
Old Aug 28, 2003 | 10:47 PM
vteg's Avatar
New User
Put subs up and port firing to the front or rear.
Old Aug 29, 2003 | 08:00 AM
chamillion's Avatar
rear deck makes a great port.
Old Aug 29, 2003 | 02:29 PM
well i do have a spot i can make the port so it fires forward, but still i dont know if it will be big enough because my amp rack takes up most of the space behind the seats, and in front of hte box.
Old Aug 29, 2003 | 02:54 PM
ok well the space that i can make the port that would fire toward the seats is about 10 inches tall and 37 inches wide. i could prolly use that?
would it still sound good w/ the port firing that way?
Old Aug 29, 2003 | 04:20 PM
vteg's Avatar
New User
Default Re: (lowlife4life)
It is easier to hear port noise when it is firing at you. But your port should not have any noise, except at loud volume.
Old Aug 29, 2003 | 04:27 PM
Default Re: (vteg)
dont you usually jus hear port noise out of little ports? i found a crx w/ the almost same design as my enclosure and amp rack, but my amp rack is at an angle instead of flat like this one.
http://www.sounddomain.com/mem...20CRX
would it help if i made 4 round ports like that one? i dunno
Old Aug 29, 2003 | 04:58 PM
rev-speed's Avatar
15s r too big 4 ur crx 2 12s would have been perfect
depending on ur box size u need to tune it to peak 12-6 frequces down from 48-51hz
and a box with the speaker facing up /port faceing the rear works best
Old Aug 29, 2003 | 05:05 PM
Default Re: (tomtomloc)
well i like 15s and ive had 2 15s before. they were sealed tho and i liked them. so im not even gonna port my box yet if i even do cuz im just gonna stick them in there sealed, im gonna be runnin 2 12s in this box till i can get the amps and 15s too so im jus gonna wait to really do anything.
Old Aug 29, 2003 | 07:47 PM
rev-speed's Avatar
this will change ur mind
world records r broken with 12s in crxs(db drag)
15s r to big because u can t make a box big enuff to fix that crxs trunk(unless u use the whole trunk and back area)
last year i build a box with 2 12 kicker squares in a crx and hit a 152.4db with a 7.5 cubic box
Old Aug 29, 2003 | 08:33 PM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomtomloc &raquo;</TD></TR><TR><TD CLASS="quote">15s r too big 4 ur crx 2 12s would have been perfect
and a box with the speaker facing up /port faceing the rear works best</TD></TR></TABLE>
I think he wanted an sql setup, not strictly spl. 40+ hz tuning does not meet that criteria.
NIKE SB'd
Classic Hondas
Feb 12, 2008 11:12 PM
ki3t
Aug 6, 2003 08:08 PM
dustywebber
Nov 5, 2002 03:35 PM
