help me design a plug and play system...
Old May 15, 2003 | 01:28 PM
JOMO
Guest
Posts: n/a
Default help me design a plug and play system...
ok, i have it all planned...
i have put handles on my sub box so it can be easily removed
i also have a box on top of the sub box with my mid range speakers...
screwed down to the side of the box is the amp...
now i want to have 'plugs' for everything so i can easily remove it every night n(i also use it as a weight, it weighs at least 100 pounds)
the speakers have a plug on them (they are stock) so thats good...
the amp now?
i don't want to have to use any tool to plug in/out the wires...
what connecter can i use? is there a plug i can buy at an electrical store for 8awg power wire?
could i design one?
it shouldnt bee too much hassle shoud it?
the speaker wire would plug easily, then there is just the rca's , power ground and remote...
will i damage rca's if i plug them in and out all the time?
help me out
edit: i also need to take into consideration the live power wire so the connecter has to conceal all raw wire...
i was thinking of one of those distribution blocks but id have to handle raw wire...
Old May 15, 2003 | 02:30 PM
1BlackHatch's Avatar
Default Re: help me design a plug and play system... (JOMO)
Go to walmart and look in the automotive electrical section.
Old May 15, 2003 | 05:44 PM
GroundZer0 336's Avatar
Default Re: help me design a plug and play system... (1BlackHatch)
at the same time your making it alot easier for someone else to take it all at once. you could just try to make it a stealth system, but have removeable covers or something. i dunno what kind of car you have or id give you an example. im trying to do this to my rex since i got my last stuff stolen.
by the way...who is that in your avatar...thems some tig ol' bitties
Old May 16, 2003 | 03:22 PM
ATF Kuk's Avatar
hey there MOJO, been wondering where uve been, MR. M.I.A. so u want a plug and play system. well for starters get banana jacks and connectors. as for the actual power 8 awg wires, some amps have it where u can unplug the whole piece, PPI amps comes to mind. and if ur worried about ur RCA's being broken, try getting 1 foot extensions or something, that way u can check if it will kill the plugs on the extensions. thats better than finding out the hard way on ur RCA's.
Old May 16, 2003 | 04:27 PM
JOMO
Guest
Posts: n/a
Default Re: help me design a plug and play system... (ATF Kuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote"> get banana jacks and connectors. </TD></TR></TABLE> are those the ones with 2 screws? that uses a flat head screwdriver?i have those but i want it so i dont need ANY tools at all
as for the power wire, im thinking of some kind of plug, or maybe a fuse i can jusat pull apart..
thanks
Old May 16, 2003 | 04:32 PM
JOMO
Guest
Posts: n/a
Default Re: help me design a plug and play system... (orgasmobile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orgasmobile &raquo;</TD></TR><TR><TD CLASS="quote">at the same time your making it alot easier for someone else to take it all at once. </TD></TR></TABLE>
not here! in jamaica, once a thief gets in...power wire and speaker wire become as insignificant as a spider web!
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orgasmobile &raquo;</TD></TR><TR><TD CLASS="quote">you could just try to make it a stealth system, but have removeable covers or something. </TD></TR></TABLE>
i have NO ide what you just said!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orgasmobile &raquo;</TD></TR><TR><TD CLASS="quote">by the way...who is that in your avatar...thems some tig ol' bitties</TD></TR></TABLE>
id love to know
Old May 16, 2003 | 04:34 PM
ATF Kuk's Avatar
go here, http://www.whirlwindusa.com/audadp01.html
Old May 18, 2003 | 06:58 AM
JOMO
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">go here, http://www.whirlwindusa.com/audadp01.html </TD></TR></TABLE>those would be PERFECT! but i'd have yo order them and **** that sucks so ill have to try something different so...
ima put a distribution block and build a sort of 'handle' that i can turn instead od using a screwdriver...you know what i mean
so i just push the power wire in and turn the handle to clamp it..
ground wire now...thats sticky....
i have only one ten in the box and 2 amps on it, ill be installing it in my new car soon as i finish fixing it (i bought it on friday but crashed it 5 minutes after purchase ) so im thinking of running the wores throught the connecters i had for the sub...
now, if i connect 8awg to the connecter will it resrict it?
its one of the small one or 2 inch square ones that you plug on the inside and just push the wire in it on the outside..
i maght just put the power and the ground through that connecter... so when removing i just plug out the sub wires on one side, plug out the ground wires on the other and plug out the (extension ) rca's....hmmm
thanks for the help
GATASboy
Audio / Security / Video
Aug 19, 2009 11:55 AM
gomillion
Mar 7, 2007 04:51 PM
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
97gSrkId88
Mar 5, 2003 01:40 PM
4doorH22
Aug 23, 2002 05:49 PM
