alpine headunit help..
Old Aug 17, 2009 | 08:39 PM
GATASboy's Avatar
Default alpine headunit help..
i have an alpine cde-9884 and is all hooked up on my 1996 integra.
problem is i dont have radio/tuner.. its just static.
what wires do i connect?
Old Aug 17, 2009 | 08:45 PM
Hyoriu's Avatar
Default Re: alpine headunit help..
there should be a plug that you plug into your stock antenna plug harness. if that's already plugged in, then check to see if your antenna is messed up I would say.
Old Aug 18, 2009 | 01:29 AM
97civic123's Avatar
pretty sure antenna plug not plugged in. it's a black plug on the back..or has a hole to plug in the antenna wire from you car...separate from the wire harness
Old Aug 18, 2009 | 04:38 AM
jason0123's Avatar
also make sure to hook up the power antenna wire if it has one
Old Aug 18, 2009 | 05:20 AM
twentyhurtz's Avatar
yea integra's have power antenna's, oddly i don't know anyone who has one that still works, they mostly are dead.. but it does not boost the signal, so as long as the ant is plugged in it should work..
Old Aug 18, 2009 | 10:13 PM
GATASboy's Avatar
yeah i didnt connect the power antenna...but where is the antenna plug located on a 1996 integra?
Old Aug 19, 2009 | 11:55 AM
Vogeezy's Avatar
you wished you lived in canada
Should just be a fairly thick black wire with a metal end on it, maybe 1cm across in size. Just plug that into the alpine deck and you are set.
civicfan18
Jun 16, 2017 05:31 AM
menthos
Apr 16, 2008 04:54 AM
scdarksol
Nov 30, 2003 09:08 PM
