Help on installing POWER Spoon replica mirrors
Old Aug 25, 2006 | 11:21 AM
kai-chun's Avatar
Default Help on installing POWER Spoon replica mirrors
I searched and couldnt find anything and people from other forums don't really know or don't wanna help. It was orginally posted in 92-00 Civic forum but they recommended me to post it up here as well. Anyways, here goes...
So i got my power replica spoons off ebay. I realized the connector plugs from the mirrors are different than the plugs that are on my stock power mirrors.
first picture is the Spoon replica plug
the second picture is the stock power mirror plug
The stock female end (not pictured) has only 3 prongs. I tried plugging the blue, brown and white from the spoons into them and motor turns but I realize it does not turn in a particular direction. So i guessed I need that fourth (black) wire connect into something.
Now, is there another way to install this? The spoon kit comes with both male and female plugs, by the way.
thanks
Old Aug 25, 2006 | 12:11 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Help on installing POWER Spoon replica mirrors (kaichun)
dam ebay, no instructions?
Old Aug 25, 2006 | 04:51 PM
02 accord's Avatar
Email the seller and ask for instructions/wiring diagram.
Old Aug 25, 2006 | 06:16 PM
Jay J's Avatar
Prince of Zamunda
Default Re: Help on installing POWER Spoon replica mirrors (02 accord)
Match the correct colors and use butt connectors
Old Aug 25, 2006 | 06:57 PM
romoracing's Avatar
Default Re: Help on installing POWER Spoon replica mirrors (Jay J)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay J &raquo;</TD></TR><TR><TD CLASS="quote">Match the correct colors and use butt connectors </TD></TR></TABLE>
But make sure you test the wires before you connect them. Use a dmm (digital multimeter) and prob the wires. Then at the switch hit the up and down side to side and you should see a voltage change. Then hook one by one to the same color wire and then test each wire and see if it does what you checked. In other words check the mirror goes down when you press the down button. If it dosent then just hook it up in another spot. Then when everything work then hook up everything.
Old Aug 26, 2006 | 11:00 AM
kai-chun's Avatar
Default Re: Help on installing POWER Spoon replica mirrors (romoracing)
I am sorry if this is dumb, i've never done electrical before...what is a butt connector??
Old Aug 27, 2006 | 05:22 PM
bpr0422's Avatar
Go here: http://www.vsracing.net/~suspended/wiring.html
Old Aug 27, 2006 | 07:07 PM
kai-chun's Avatar
Default Re: Help on installing POWER Spoon replica mirrors (bpr0422)
thanks for teaching me how to fish rather than just giving me the fish! I will definately go thru that.
but...if anyone else wants to just gimmie the fish, that is still welcome.
Old Aug 29, 2006 | 05:14 AM
bpr0422's Avatar
that website teaches u everything on basic wiring...
the12volt.com for more complicated wiring things...
but wiring isn't hard...at all...
crimps, solder, and eletrical tape are ur three tools...
if u want you can add in a heat gun and some shrink tubing... but eletrical tape wrapped tightly around a wire does the same job
WeeMan
Apr 13, 2007 01:02 PM
kai-chun
Aug 26, 2006 11:01 AM
95egSi
Oct 9, 2004 10:18 AM
