HELP installing power door locks
Old Oct 7, 2002 | 04:38 PM
Airbag Club's Avatar
Default HELP installing power door locks
Hi, I have a 99 Civic HB, and I have a Clifford Intelliguard 8000. I did not have power door locks installed when I got the alarm because I was low on money. I recently purchased a 2-wire power door lock kit, and I want to install it onto my clifford. I am really confused which wires I should hook up the two wires to. The door lock kit is a DEI kit, and one wire is green and the other blue. What do I hook up to what? The choices are door lock normally open, door lock normally closed, door unlock normally open, and door unlock normally closed. If you know how and what to wire it up to, please help!!! Thanks!
Old Oct 7, 2002 | 08:33 PM
audioroach's Avatar
Default Re: HELP installing power door locks (Project CTR)
What you have is a reverse polarity motor system...when 12vts is applied to one wire and ground is applies to the other the motor will open or close. Your Intelliguard 8000 should have the relays on board to work the motors...try this link directed.com to get some info.
[Modified by audioroach, 11:34 PM 10/7/2002]
Old Oct 7, 2002 | 11:44 PM
Default Re: HELP installing power door locks (audioroach)
alright, thanks.
Old Oct 8, 2002 | 02:08 AM
HandCommand's Avatar
If it were me, I'd use 5 wire door locks in each door. That way, it will act as a central door locking system when used with the KEY. Then all you would need to do is send neg. or pos. signals the already installed relays from the Central Doorlock Kit for keyless entry.
But, if you already bought the 2 wire ones, follow what Audioroach said. The Clifford is nice in that it already has the relays built in to use.
steveharrmr23
Audio / Security / Video
Nov 19, 2008 01:41 PM
carcraftlude
10
Oct 3, 2008 07:56 AM
saveacivic
21
Jan 24, 2007 07:18 PM
Sanj
Oct 2, 2005 08:22 AM
