Help Identify Audio Problem
Old Nov 28, 2009 | 06:18 PM
DeliveryM2n's Avatar
Default Help Identify Audio Problem
Hi everyone
First time posting in the audio forum and let me just first say I'm really newb when it comes to audio stuff. My problem is a few months ago someone broke into my car and stole my subwoofer, so I just recently got a new sub to replace it. It didn't work when I tried to hook it up, but I was able to make sure that the sub works (connected it the speaker wires). I don't know what is wrong with the setup. I figured if the thieves just pulls out the sub box, everything else should still work properly right? None of the fuses are blown and the amp lights up and everything. I also checked to make sure there is no cuts in the wire. Do you guys have any suggestions on what I can do next? How can I check to make sure the amp works? Thanks in advance.
Old Nov 28, 2009 | 09:40 PM
dohcvtak's Avatar
Default Re: Help Identify Audio Problem
amp light up n everything...but no sound...
rca still connected both hu and amp?
u can test by trying any old speaker on it...
Old Nov 29, 2009 | 02:50 AM
yea everything is still connected. the thieves just ripped out the sub box... everything else was left intact...
Old Nov 29, 2009 | 09:51 AM
fcm's Avatar
fcm
Old Fart
Did you make sure the speaker leads did not touch each other after the sub was stolen and you turned on the system.
If nothing else was touched, [except sub] and the speaker leads from the sub amp touched ground or each other and the amp is turned on, [you turning system on] the outputs on the amp will blow. 94
Old Nov 29, 2009 | 11:36 AM
hmmm... that is a possibility. I mean I left the wire hanging for a few months now before I got a new sub. Even if the outputs of the amp blew, would it still turn on?
Old Nov 30, 2009 | 05:53 AM
fcm's Avatar
fcm
Old Fart
That depends on the amp, but on many amps yes it will turn on, on some amps the indicator, [LED] is powered directly by the turn on lead.
What is the make and model of the amp? 94
miss.Soshinoya
Audio / Security / Video
Jul 29, 2010 03:58 PM
deerman2701
Oct 9, 2008 07:48 PM
del sol1658
Aug 8, 2006 05:04 PM
Feuerraeder
Dec 24, 2002 09:06 AM
93civdx
Dec 22, 2002 11:06 AM
