HELP ASAP do i need to ground the head unit
Old Oct 18, 2005 | 01:50 PM
jamie_honda_08's Avatar
Default HELP ASAP do i need to ground the head unit
i have a amp im hooking up and all so do i have to ground the head unit and the amp or just the amp or what?
anyhelp plz
Old Oct 18, 2005 | 02:10 PM
91DroppedHatch's Avatar
just ground the amp to the part on the amp that says ground, and make sure ure connect the radio wire(from the head unit) and the audio plugs(re/white) to the amp.
Old Oct 18, 2005 | 02:12 PM
Default Re: (91DroppedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91DroppedHatch &raquo;</TD></TR><TR><TD CLASS="quote">just ground the amp to the part on the amp that says ground, and make sure ure connect the radio wire(from the head unit) and the audio plugs(re/white) to the amp. </TD></TR></TABLE>
i dont get what you mean
Old Oct 18, 2005 | 02:17 PM
capdaddy222's Avatar
Default Re: HELP ASAP do i need to ground the head unit (jamie_honda_08)
It depends on your head unit. Most head units do not have large enough internal amplifiers to require a separate ground. They are grounded through the wiring harness to a common chassis ground for various other electrical accessories.
Some head units like the better Alpine units have separate grounds. You MUST Ground one of these units. If you try to splice into the wiring harness you will just end up blowing fuses in your head unit and having to pull it back out to replace them.
Amps always are grounded. Usually with short (less than 3') wires of equal or larger guage than your power wire.
Good grounds make cleaner power and will keep you from getting "gremlins" in your system.
Good Luck
Old Oct 19, 2005 | 12:19 PM
fcm's Avatar
fcm
Old Fart
Whats the make and model of the Hu and MM&Y of car?
capdaddy222 is correct you probably don't need anything more then the oem radio ground for the aftermarket HU, if you do running a ground wire from the back brace screw to the chassis of the car will work just fine, or just running the HUs ground wire to the chassis.
That said, if the HUs internal amp is that big, [anything over 10W x 4 RMS] you should be running a power wire from the batt., [just like the amp] to behind the HU and connecting the HUs constant power, [yellow] to it.
Of coarse if you are not using the HU internal amp for any speakers, you can go ahead and just use the oem radio harness constant power and ground.
As for the amp ground use an existing bolt, [seat, seat belt] as close to the amp as convenient to ground the amp, [don't forget to scrap off any paint so the ground makes contact with bare metal. 94
Old Oct 19, 2005 | 04:28 PM
installed it all tonight
wow big bass man
sounds sweet
thx guys
ht rules
i was going to sell my system but it sounds so good in my new car i might not
driftahboi
Audio / Security / Video
Apr 30, 2008 08:16 AM
kharned08
Honda Civic (2001 - 2005)
Dec 4, 2007 06:51 PM
DC2 to AP2
Nov 10, 2006 08:30 AM
bigD
Nov 8, 2002 07:54 AM
