help?
Old Jun 4, 2009 | 03:39 PM
89civicsiowner's Avatar
Default help?
so ive been running around with no radio for like 3 months, finally got a new pioneer head unit, tried hooking it up with no luck i cant figure out what im doing wrong, i have the battery wire from the radio hooked to the white/blue constant wire in the dash, the red accesory wire from the deck is connected to the yellow/red ign wire in the dash, the ground is hooked up and the illum is hooked to the red/black wire in the dash, i have an 89 civic si also by the way, what am i doing wrong?
Old Jun 4, 2009 | 05:10 PM
fcm's Avatar
fcm
Old Fart
Default Re: help?
Have you checked the fuses that protect the constant, [white/blue] and switched, [yellow/red] leads? 94
Old Jun 4, 2009 | 05:14 PM
Default Re: help?
like in the fusebox or in the dash somewhere?, if you didnt guess im new at this
Old Jun 4, 2009 | 08:16 PM
dj-t's Avatar
Default Re: help?
Yup, fuse box under the driver dash and in the engine bay
Old Jun 5, 2009 | 07:25 AM
Default Re: help?
yep checked, no blown fuses, the deck is a newer pioneer, could it have a anti-theft system im not aware of?
Old Jun 5, 2009 | 08:26 AM
dj-t's Avatar
Default Re: help?
What about the fuse on the the back of the radio.
If not the fuse on the radio double check the constant wire if it has 12v through it at all times the ignition 12v only when you turn the key on and make sure you have a good ground check resistance if not sure just run your own ground. You only need these three to turn on the radio.
Did you check all the fuses cause I think clock, cigarette, and domelight fuses also links to the radio. Meter all the fuses make sure that they get 12v on both ends some times the fuses may not look blown to the eye but they are.
Old Jun 5, 2009 | 09:53 AM
Default Re: help?
yep the lighter fuse was burnt, got it in and working, thanks guys
vtak2nr
Audio / Security / Video
Sep 8, 2011 08:02 PM
efjones9
Jun 10, 2009 08:33 AM
z6htch
Feb 1, 2009 06:16 PM
the1337couch
14
Apr 27, 2007 02:20 PM
WHIT
Nov 24, 2002 08:36 AM
