Headunit stops working
Old Mar 25, 2008 | 09:27 PM
Cyber ITR's Avatar
Default Headunit stops working
Hey guys, I have a dc1 integra when i was trying to install a band expander all of a sudden the headunit just stops working, it still able to eject the disc just no lights comes on.
I have replaced all the 7.5amp fuses under the engine bay and all the ones under the dash and still doesnt work, i just tried to connect a brand spanking new headunit and still not powering up
Please help
Old Mar 26, 2008 | 04:08 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Headunit stops working (Cyber ITR)
Most HU's have a fuse on the back of them as well. Might wanna pull it out, check the connections and the fuse as well. Do you have access to a multi meter?
Old Mar 26, 2008 | 08:57 PM
Cyber ITR's Avatar
Default Re: Headunit stops working (White Smoke)
its a brand spanking new out of the box headunit and the fuse is fine
and i can get hold of multi tester , where should it start ???
thanks :D
Old Mar 27, 2008 | 02:21 AM
i my honda
Global Mod
Check and make sure you have 12volts on the red and yellow wire going to the head unit. Also check continuity on the black wire to ground.
vtak2nr
Audio / Security / Video
Sep 8, 2011 08:02 PM
kirkland08
Jun 17, 2010 09:12 PM
superchi
Oct 26, 2008 03:49 PM
ThinkRevolution
14
Aug 10, 2008 04:35 PM
tgctruly
Oct 17, 2004 08:51 PM
