Headunit install problems
Old Jan 30, 2014 | 04:50 PM
Vlad_amire's Avatar
Default Headunit install problems
So i recently purchased a new headunit for my 91 hatch and i hooked up all the connections and adaptors. I plug it in and hear it getting power but it wont light up or actually "power on". If anyone could help me out thatd be great!
Old Feb 15, 2014 | 09:40 AM
1997blackaccord's Avatar
Default Re: Headunit install problems
Its the ignition on wire in you cars harness. Try twisting your yellow and red wires on back of head unit together and if it comes on then you have a wiring problem you need to find. Or leave it that was and manually turn the stereo off when turn car off.
Old Feb 23, 2014 | 04:43 PM
Vlad_amire's Avatar
Thank you for getting back to me ive tryd that and still not luck, the problem is somewhere in my car because i tried the headunit in my buddies ef and it worked
Old Mar 2, 2014 | 02:09 PM
Jabuelouf's Avatar
What brand/model is the headunit?
Old Mar 5, 2014 | 09:42 PM
underrated's Avatar
Did you check your fuses?
Old Apr 9, 2014 | 10:11 PM
NerfGunner420's Avatar
wow. tard. simple. multimeter. measure voltages at red wire on harness and yellow. problem solved. plus its better to run after market stereos directly to power then those skinny skimpy wires in the cars harness
Old May 5, 2014 | 11:43 PM
4DoorBoom's Avatar
Did you hook up remote wire? You need a remote lead that will give the radio a signal to turn on when key is on and to turn off when you turn ignition all the way back and take your key out. Just make sure your remote wire isn't hooked directly to battery or else your radio will stay on all the time.
Old May 8, 2014 | 07:45 PM
Jrodseg6's Avatar
I would check fuses use a volt meter to see where your not getting power from.
stinkypinky1011
Jun 23, 2014 06:13 AM
nauticalstar80
23
May 20, 2009 05:18 PM
B20EF
Engine Management and Tuning
May 15, 2009 10:57 PM
acman1
Mar 30, 2003 12:48 PM
rota426
Audio / Security / Video
Jun 18, 2002 04:17 PM
