Headlight kill switch?
Old Mar 2, 2008 | 06:28 PM
em12nv's Avatar
Default Headlight kill switch?
Does anyone have a kill switch for the headlights. I was thinking of doing this - the reason - when theives steal cars they mostly do it at midnight, when its dark. So, when the police see they are not driving with the lights on they get stop. If someone has done this , how did you do it.
Old Mar 2, 2008 | 11:44 PM
bpr0422's Avatar
Default Re: Headlight kill switch? (em12nv)
why not just kill the main relay?
prevent it from starting, running, and it throws lots of codes!
Old Mar 3, 2008 | 04:55 AM
White Smoke's Avatar
i my honda
Global Mod
It can be done but there are much better kills (Main Relay for Example).
All you would need is a SPDT automotive relay. You can wire this to the factory headlight relays ground wire. Check out these two links, they should get you started.
http://www.the12volt.com/relays/relays.asp
http://www.the12volt.com/relays/page2.asp
Old Mar 3, 2008 | 11:20 AM
em12nv's Avatar
Default Re: Headlight kill switch? (White Smoke)
I have a ecu kill and fuel.
Can you show a pic or point me to the way the headlight relays ground wire is.
Old Mar 3, 2008 | 12:33 PM
i my honda
Global Mod
We would need to know what kind of car you had...
Old Mar 4, 2008 | 12:06 PM
ls_bitik's Avatar
how do you do a main relay kill? noob ques!
Old Mar 4, 2008 | 06:38 PM
em12nv's Avatar
Default Re: Headlight kill switch? (ls_bitik)
I have an em1.
Old Mar 4, 2008 | 09:16 PM
bpr0422's Avatar
You know that a headlight kill, both high and low..
is going to require 4 relays.
I dunno the best place to tap into it either, the engine bay is too visible, and under the dash, just adds more junk....
the easiest way to check for the color, is look at the plug at the head light...
on pre ES chassis - i think the headlamps are positive trigger...
black is always ground, the others, well one is high and one is low...
Old Mar 5, 2008 | 05:42 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_bitik &raquo;</TD></TR><TR><TD CLASS="quote">how do you do a main relay kill? noob ques! </TD></TR></TABLE>
Install a switch on the PGM-FI Main Relay, [main relay] black ground lead, it is the ground for the injector relays coil, it will cut power to the injectors, fuel pump, one of the powers for the ECU/ECM and a few engine sensors, it is a low current ground so only a small (1A) switch is needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">You know that a headlight kill, both high and low..
is going to require 4 relays.</TD></TR></TABLE>
Actually you only need one relay, install it on the power input lead to the "Combination Light switch", probably a white lead, it will cut power to all lights controled by the head light switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em12nv &raquo;</TD></TR><TR><TD CLASS="quote">I have an em1.</TD></TR></TABLE> For us no0bs, what is an em1? 94
Old Mar 5, 2008 | 09:26 AM
i my honda
Global Mod
Default Re: Headlight kill switch? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> For us no0bs, what is an em1? 94</TD></TR></TABLE>
99-00 Civic Si
Old Mar 5, 2008 | 08:38 PM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Actually you only need one relay, install it on the power input lead to the "Combination Light switch", probably a white lead, it will cut power to all lights controled by the head light switch. </TD></TR></TABLE>
Didn't think about that... but wouldn't that kill EVERY light...
turn signals, parking, headlights, high beam?
might just do that so, i don't end up with a dead battery when i arm the car XD
but i think its a little too dangerous... cause if the relay fails, you loose all your lighting, in one shot...
you loose your fuel.. not as dangerous.. you can still steer... sorta.. and you still have lights to see ahead of you...
Old Mar 6, 2008 | 06:03 AM
fcm's Avatar
fcm
Old Fart
Default Re: Headlight kill switch? (bpr0422)
Why would it kill the signal lights, all you are doing is cutting power to the head and park lights.
The chances of the relay failing are about the same as the fuse blowing when there is nothing wrong. 94
spcrxracer
Audio / Security / Video
Oct 16, 2011 08:54 PM
GS8HFL21
Nov 9, 2005 06:56 AM
tianporn
15
Feb 21, 2005 07:56 PM
