head unit wiring help needed
Old Apr 16, 2003 | 06:34 PM
RTE117's Avatar
Default head unit wiring help needed
there are two wires used for power, one's switched and one's constant.. On my alpine one of the power wires has a fuse on it which one do I wire that to? I did this on my Accord and I have no idea which one I used. Thanks
Old Apr 16, 2003 | 06:46 PM
t0p_sh0tta's Avatar
Default Re: head unit wiring help needed (IDriveAHonda)
They both get connected to the car's power wire. Well, that is if I understood you correctly.
Old Apr 16, 2003 | 07:04 PM
VTECorona's Avatar
Default Re: head unit wiring help needed (t0p_sh0tta)
i think yellow goes to the constant + (should be the fused one), and the red goes to ignition on\off
To test if its right try to turn your stereo on while the ignition is totally in the off position, if it turns on then its wrong and switch the wires around. If it doesn't turn on then turn your ignition into position II and it should turn on if its right.
Old Apr 17, 2003 | 07:51 PM
HiRevn's Avatar
Default Re: head unit wiring help needed (97RedTegGSR)
Is your OEM wiring harness still intact? If it is, I would just go and buy a wiring harness. They sell them at Circuit City, Best Buy, etc, for about $10-15.
But yeah, the yellow wire with the fuse on it, goes to constant power, and the red is switched.
Old Apr 17, 2003 | 07:53 PM
STK B16's Avatar
Default Re: head unit wiring help needed (HiRevn)
yellow is constant. red is acc
hondaboyqj
Feb 5, 2019 06:28 PM
j4s0n1337
May 6, 2011 12:00 PM
DC2_Legend
Apr 22, 2011 03:39 PM
ekslammed
Audio / Security / Video
Dec 17, 2007 05:18 AM
Tano
Jun 14, 2007 07:41 AM
