Which head unit to run!
Old Feb 17, 2005 | 08:55 PM
milton's Avatar
Default Which head unit to run!
I have a jl audio 1000/1 and a 13w7.. which head unit is the best to run? which model? anyone using this setup?
Would i need to run a cap? Im not into the car audio thing, but installing these suckers.. help!
Old Feb 18, 2005 | 07:18 AM
fcm's Avatar
fcm
Old Fart
Default Re: Which head unit to run! (milton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milton &raquo;</TD></TR><TR><TD CLASS="quote">I have a jl audio 1000/1 and a 13w7.. which head unit is the best to run? which model? anyone using this setup?
Would i need to run a cap? Im not into the car audio thing, but installing these suckers.. help! </TD></TR></TABLE> Go with an Alpine, that is what we use on our JL demo board, and yes, add a cap, you may want to think about upgrading the cars alt. also. 94
Old Feb 18, 2005 | 12:14 PM
milton's Avatar
Default Re: Which head unit to run! (fcm)
wat model?
Old Feb 19, 2005 | 05:43 PM
ANDREW D's Avatar
Defiantly run a 1 farad cap. i would suggest running an Eclipse head, but really any head unit with at least 4 volt pre-out will do.
Old Feb 19, 2005 | 09:22 PM
milton's Avatar
Default Re: Which head unit to run! (ANDREW D)
which head unit and model #
Old Feb 20, 2005 | 09:22 PM
Olegus's Avatar
Depends on a budget.
If you can affor this one, than go for it:
http://iweb.alpine-usa.com/pls...in=10
If that's not enough, there's F#1Status:
http://www.alpinef1status.com/....html
Older models like 9813-15 are pretty good too
A new line has been released a couple of months ago, you might wanna check them out. Make sure you listened and compared enough before you buy.
Old Feb 20, 2005 | 10:09 PM
Goatsterrman's Avatar
Default Re: Which head unit to run! (Olegus)
I would go with an Eclipse unit. Definately atleast a 5 volt model.
You will need to get atleast A 1-farad cap. I've seen that amp kill charging systems. You even run a decent chance of needing a larger alt.
Old Feb 21, 2005 | 08:41 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milton &raquo;</TD></TR><TR><TD CLASS="quote">wat model?</TD></TR></TABLE> They are all very good, go to http://www.alpine.com and check them out, what HU you go to will depend on how much you want to spend and what you want your HU to be able to do, the "look" of the HU may be a facter also.
Remember the HU is the most important part of your system, in the end, how the system sounds and how much control you have will depend on the source, [ the HU] You should sit down, take a min., and deside what you want the HU to be able to do in the end, as you build your system, you don't want to get to a point where you have to say to yourself, chit I should have gotten the HU that had this or that
So take your time, go to your local car audio shops and check out the HUs on the demo boards 94
funtak
Audio / Security / Video
May 15, 2007 10:13 AM
mr poo
15
Nov 22, 2006 05:51 PM
Matty.
63
Feb 14, 2006 12:41 AM
c'mon
Mar 28, 2005 06:13 AM
frostwhite_92
Jan 16, 2003 08:23 AM
