Head Unit Install ...NEED HELP!
Old Oct 11, 2002 | 12:40 PM
Cav's Avatar
Cav
Default Head Unit Install ...NEED HELP!
hey my sis x-bf ripped her head unit out so now i gotta install it, but ive never done car audio before
so here is the deal she has the power plug, atenna plug and 4 other plugs
now i know where the power plug goes and the atenna plug but ive tried numerous comb's with the other plugs and to no luck for sound
now she also has a equlizer which im guessing is hooked up to her amp then to her 2 15inch eclipes but i cant find any plugs to run the equlizer to the head unit
my guess would be the 4 plugs would go into one of the front/rear and audio out holes and the sub out from the deck would plug into the equilzer but liek i stated i cant find any equlizer plugs.
i included a diagram of the back of the deck to help you guys since my english sucks, and its my first launage hehehe
its linked to geocities so you will probley have to open a new page and paste the link in ( http://www.geocities.com/jasons_pics2000/stupid.bmp )
thanks for any help guys
Old Oct 11, 2002 | 01:04 PM
RegRedTeg's Avatar
Default Re: Head Unit Install ...NEED HELP! (Cav)
What do you mean by 4 plugs, is this on back of the headunit or coming out of the dash. The headunit depending on which one it is should have a antenna plug and just the wiring harness (the power is on the harness). and whatever amount of preouts she has most high end decks have 3-4.
Old Oct 11, 2002 | 02:23 PM
Cav's Avatar
Cav
Default Re: Head Unit Install ...NEED HELP! (RegRedTeg)
she has 4 plugs comming from the dashboard (not including the power plug and attena)
and she has 2 cables comming out from the deck that say sub out on them
im so confused hehehe
Old Oct 11, 2002 | 02:42 PM
RegRedTeg's Avatar
what do you mean by plugs are they rcas??? and how many amps is she running.
Old Oct 11, 2002 | 06:30 PM
gokuson's Avatar
do the 4 plugs look like plugs that go to a vcr? what color are the plugs?
if so, then they could be running to the equalizer then to the amp. Does your sis have a cd-changer? if so two of these plugs might go to it.
if she doesn't, then prob the 4 plugs goto the equalizer. how many amps and how many channels per each amp does ur sis have(ie she has 2 amps with 2 channels for each amp).
Shockfire10
Sep 4, 2010 08:43 PM
Tim2179
Apr 24, 2009 08:16 AM
xunkn0vvnx
Audio / Security / Video
Aug 6, 2007 08:10 PM
NickGSR95
May 18, 2004 11:20 AM
